この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Use this guide to replace a broken ambient temperature sensor.
必要な工具と部品
Loosen the two Phillips screws securing the access door to your iMac.
Remove the access door.
Remove the following screws along the lower edge of your iMac:
Three 6 mm T8 Torx screws
One 8 mm T8 Torx screw
To lift the front bezel off the iMac, simultaneously:
Use your thumbs to press in the RAM arms and hold the iMac down.
Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
Pull the front bezel up with your index fingers.
Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
Pull the ambient temperature sensor cable out of its socket on the logic board.
ある他の人がこのガイドを完成しました。
