メインコンテンツにスキップ
iMac Intel 21.5" EMC 2428 PRAM Battery Replacement
必要な工具と部品
  1. iMac Intel 21.5" EMC 2428 PRAM Battery Replacement, Glass Panel: 手順 1、 2の画像 1 iMac Intel 21.5" EMC 2428 PRAM Battery Replacement, Glass Panel: 手順 1、 2の画像 2
    この手順で使用する道具:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    購入する
    • Before beginning, unplug your iMac and lay it on a soft surface as shown.
    • Stick a suction cup near each of the two top corners of the glass panel.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
  2. iMac Intel 21.5" EMC 2428 PRAM Battery Replacement: 手順 2、 2の画像 1 iMac Intel 21.5" EMC 2428 PRAM Battery Replacement: 手順 2、 2の画像 2
    • Gently lift the glass panel perpendicular to the face of the LCD enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
    • Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
    • During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
  3. iMac Intel 21.5" EMC 2428 PRAM Battery Replacement, Display: 手順 3、 3の画像 1 iMac Intel 21.5" EMC 2428 PRAM Battery Replacement, Display: 手順 3、 3の画像 2 iMac Intel 21.5" EMC 2428 PRAM Battery Replacement, Display: 手順 3、 3の画像 3
    • Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
    • The last two pictures are detail shots of each side of the display.
  4. iMac Intel 21.5" EMC 2428 PRAM Battery Replacement: 手順 4、 1の画像 1
    • Slightly lift the top edge of the display out of the outer case.
    • Do not lift it too much. There are several cables attaching the display to the logic board. Twisting or pulling the display assembly with the cables attached will damage your iMac.
  5. iMac Intel 21.5" EMC 2428 PRAM Battery Replacement: 手順 5、 2の画像 1 iMac Intel 21.5" EMC 2428 PRAM Battery Replacement: 手順 5、 2の画像 2
    • Pull the vertical sync cable connector out of its socket on the LED driver board near the top left corner of your iMac.
  6. iMac Intel 21.5" EMC 2428 PRAM Battery Replacement: 手順 6、 2の画像 1 iMac Intel 21.5" EMC 2428 PRAM Battery Replacement: 手順 6、 2の画像 2
    • Rotate the display out of the outer case enough to disconnect the LED backlight power cable from the LED driver board.
    • Disconnect the LED backlight power cable by depressing the locking mechanism while pulling the connector away from its socket (toward the bottom edge of the iMac).
  7. iMac Intel 21.5" EMC 2428 PRAM Battery Replacement: 手順 7、 3の画像 1 iMac Intel 21.5" EMC 2428 PRAM Battery Replacement: 手順 7、 3の画像 2 iMac Intel 21.5" EMC 2428 PRAM Battery Replacement: 手順 7、 3の画像 3
    • Grab the plastic pull tab secured to the display data cable lock and rotate it towards upwards.
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
  8. iMac Intel 21.5" EMC 2428 PRAM Battery Replacement: 手順 8、 2の画像 1 iMac Intel 21.5" EMC 2428 PRAM Battery Replacement: 手順 8、 2の画像 2
    • Disconnect the LCD thermal sensor cable connector from its socket on the logic board.
  9. iMac Intel 21.5" EMC 2428 PRAM Battery Replacement: 手順 9、 1の画像 1
    • Carefully pull the display toward the top edge of your iMac and lift it out of the outer case, minding any cables that may get caught.
  10. iMac Intel 21.5" EMC 2428 PRAM Battery Replacement, PRAM Battery: 手順 10、 2の画像 1 iMac Intel 21.5" EMC 2428 PRAM Battery Replacement, PRAM Battery: 手順 10、 2の画像 2
    • Use the tip of a spudger to pry the PRAM battery out of its socket on the logic board.
    • The PRAM battery is a BR2032 lithium coin cell.
終わりに
10 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Walter Galan
694,840 ポイント
1,203のガイドは作成済み
2 件のコメント
Is this the same battery and procedure for the mid 2011 27”?
Maor Roffe - 返信
is this the solution of fixing the black screen after press the power bottom behind when starting or restart?
bananaorange guy - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 29
過去 30 日: 107
今までの合計 23,146
