はじめに
Use this guide to replace your logic board's BR 2032 PRAM battery.
必要な工具と部品
この手順で使用する道具:Heavy-Duty Suction Cups (Pair)$14.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Use the tip of a spudger to pry the PRAM battery out of its socket on the logic board.
10 の人々がこのガイドを完成させました。
2 件のコメント
Is this the same battery and procedure for the mid 2011 27”?
Maor Roffe - 返信
is this the solution of fixing the black screen after press the power bottom behind when starting or restart?
