はじめに
Use this guide to replace the sleep light/IR board.
必要な工具と部品
この手順で使用する道具:Heavy-Duty Suction Cups (Pair)$14.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Pull the IR board connector toward the top of the iMac to disconnect it from the logic board.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
