はじめに
Replace a broken AirPort card to regain Wi-Fi connectivity.
必要な工具と部品
この手順で使用する道具:Heavy-Duty Suction Cups (Pair)$14.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Use the flat end of a spudger to pry all three AirPort antenna cable connectors up from their sockets on the AirPort card.
10 の人々がこのガイドを完成させました。
コメント 1 件
Inversion de CH / CH inversion :
J'ai constaté deux fois le même problème en changeant le HDD.
J'ai connecté normalement et ça fonctionne.
I have seen the same problem twice by changing the HDD.
I connected normally and it works.
Avant / Before : 0 = CH 2/1 = CH 1/2 = CHO
Après / After : 0 = CH 0/1 = CH 1/2 = CH 2
