はじめに
Use this guide to replace the GPU card.
Unplug your iMac's AC cord along with any peripheral devices.
Lay your iMac face-down on a soft, clean surface as shown.
Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
Remove the access door.
Gently slide the black plastic RAM pull tab out from the RAM slot.
Pull the black plastic tab away from the bottom edge of the iMac to eject the module(s) on that side of the RAM bay.
It is far harder than I thought you have to pull REALLY hard and then there will be a little click and than you can gently pull out the RAM.
Press really hard, to the point you think you’ll cut your thumb, you’ll hear a slight ‘click’. If it’s not properly installed, the iMac will ‘beep, beep, beep’ In protest upon booting…
Brian -
I found it best to make use of the factory ‘pull tabs’. Much much easier than trying to pull the ram out by hand. It may seem like a good idea but, don’t be tempted to use pliers.
Brian -
Thanks for your Useful guide …. iMac Intel 21.5" EMC 2428 RAM Replacement was performed step by step on my Imac and every thing is perfect right now.
I was able to remove one side of the ram, but the other side would not budge. I was afraid that I was going to rip the plastic tab out of the computer. Any suggestions?
Be sure the small notch cut into each RAM module (shown in the first picture) mates with the protrusion in each RAM slot (shown in the second picture).
When reinstalling RAM in this machine or any iMac with upgradable RAM slots push hard to get them to go in (Apple really did make this one harder than it needed to be). If you don't push hard it won't go in and your computer won't work. (trust me on this learned the hard way)
I am having trouble with bottom 2 slots. As I get beeping sounds when using them. When removed it boots properly. I tried & tried to push the 2 , 2GB ram modules into the bottom slots BUT all get is beeping. Guess I have to settle for 4GB Rather than 8 unless someone has a suggestion.
Try swapping the to the other slots & don’t forget to press really hard until you hear the ‘click’.
Brian -
Is there an expirience to settle 1600 MgH Ram instead 1333 MgH manual required?
Added 16GB for a total of 20GB, runs great, do make sure of the “click”, the beep is disturbing
2x2 GB 1333 MHz RAM were installed as delivered. I couldn’t manage to get those two out of their slots. I don’t want to damage anything. So, I put 2x8 GB RAM 1333 MHz RAM bars in the other two empty spare slots to have 20 GB RAM in total. The iMac runs fine with it. As described above, make sure to push RAM until they ‘click’ in completely.
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Another comment on DATA & LCD Temp. Sensor cables: I had to remove the vertical sync, and the backlight cable, however, if you have an assistant or/can carefully rotate the screen clockwise/and then have it held up about 5" to 6" at a slight angle, you do not need to remove LCD data cable or LCD thermal cable, however - IMPORTANT: you must have a second pair of hands/or way to securely prop up the LCD. Also, don't rotate too much, since then you will pull out LCD data cable, and it renders the whole exercise moot, or can damage the cable or connector.
You don't need suction cups. The screen, held by magnets, can simply be pried off using a very thin blade such as a screw driver and fingers.
That's a bad idea. using a metal tool to pry off glass is likely to end with an expensive broken front glass.
Suction cups are common. Find a couple and do it the safe way. I use some cheap ones that came with iPhone repair kit.
No need for suction cups, I just stuck my nails (short like guys usually have) between the top part of the screen and body, and it came off easily. I've never done it before, so it seems to be very easy.
Just completed the replacement of the optical drive with an SSD using an OWC Data Doubler kit. Attempted to remove the optical drive without disconnecting any cables but found it a bit fiddly to orient the screen for good access. I bit the bullet and disconnected them and found the process less daunting than I imagined. Reconnecting them was similarly straightforward if you're careful.
Tip: you can skip the step for removing the optical drive thermal sensor connector from the motherboard. Still need to remove the sensor from the optical drive but you can leave that hanging and reattach it to the SSD later.
I’ve just successfully installed a 1TB SSD in place of my optical drive thanks to the information here- thank you to everyone who has contributed!
3 comments- the procedure described here seems to vary between HD replacement and dual HD/optical drive replacement. This can be confusing at times.
Expect there to be minor differences between the layout described and what you find when you open up your iMac. There are also, surprisingly, differences between the HD enclosure description, and the article provided by ifixit.
I was able to replace the DVD/HD enclosure single-handedly without fully removing the LCD, or deconnecting any of the cables (steps 5-11). It’s a bit cramped, and fiddly, but I was not happy removing any of the cables despite watching videos, etc., since they all seemed to involve applying more force than I was comfortable with. A more detailed description of how to release them might have helped, but even here, there may be minor variations even within the 2389 model.
Good luck!
ivan birks - 返信
Fingernails are all you need to free the glass from its magnetic hold. If you don’t have them, slip something thin and plastic, like a spudger, at a top corner.
Max Powers - 返信
Minha dúvida é a seguinte: após o técnico trocar o HD do meu iMac de 21,5 polegadas, a câmera parou de funcionar. Seria por causa da troca do HD? Tem solução?
Creio que o cabo da camera não foi plugado ou deu mau contato… ou até danificado.
glecyo@gmail.com
I can’t get my glass to budge. I’m replacing a cracked one and now it’s about to shatter.
Gently lift the glass panel perpendicular to the face of the LCD enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
What's the best product to clean the face of the LCD?
Microfiber Cloth
Try your best not touch it in the first place
Brian -
Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
Replacing the screws , especially the two uppermost ones , is awkward due to the magnets attracting the screws off the Torx driver
I’ve just replaced the screws by making a little tube from paper and wrapping it round each screw to keep it contained. A cut-down straw would be perfect for job.
I second this but use a tube of cardboard instead, then its quite easy.
jeank75 -
Slightly lift the top edge of the display out of the outer case.
After sliding the display slightly towards the top edge, enough for the bottom edge to clear the retainers, an alternative is to raise the bottom edge out. Then unplug the LED backlight power cable (this step + 2), unplug the LCD thermal sensor cable (this step + 4), unplug the display data cable (this step + 3), and the display may be rotated over the top edge while leaving the vertical sync cable attached (this step + 1).
Pull the vertical sync cable connector out of its socket on the LED driver board near the top left corner of your iMac.
Do not try to pull the plug off the circuit board as it's soldered. Pull the cable sideways out of the socket.
Skipped step 5-10. I used two 5-6" chopsticks to prop up the display, this gave me more than enough room to complete the rest of the steps. I only had to disconnect the 3 cables are directly connected to the hard drive. Replacing the Seagate hard drive with another Seagate hard drive eliminated any cable issues. Now I have 2TB SSDH
I was also able to skip steps 5 thru 10, which meant no messing with any cables except for the two for the HD (steps 13+14). Used a credit card to start the removal of glass panel (step 2) - much easier than I imagined. After removing display screws (step 3) I simply had a friend hold up the display's bottom edge as far as the cables would allow (careful not to stress at connection to logic board) and this provided enough room to remove the HD bracket screws (step 11), detach the HD cables, and remove the HD. Was replacing a failed 1TB Seagate with a 3TB Seagate so no problems with compatibility when reattaching the HD cables and everything worked fine when I restored the OS and data to the new HD. No fan issues. I did take great care to not get fingerprints on the inside of the glass panel and to blow off any dust specks before reinstalling it. It was a bit tricky to get the new HD back in without letting the magnets get a hold of it, so thanks for the warning posted here about that!
On my mid 2010 Imac I found it was not necessary to disconnect any cables (except of course those attached to the drive). Simply angle the monitor away from the case to a safe distance without stressing any cables and secure with tape. With a stubby screw driver it was easy to access and remove the drive.
Skipped steps 6-10; did step 5 so could lift top of display higher, then propped up. A photo of whole interior here would help (hard disk is top center). Used pliers holding T10 bit at right angle to unscrew hard disk holder. SSD installed loose (macOS and fan control app already loaded).
Pull the display data cable straight out of its socket on the logic board.
This cable is very short, I would remove it before any of the others. First time I did this, I didn't realize this and this cable just popped out of it's socket. Luckily, the board wasn't damaged.
maccentric - 返信
i damaged my (step7) cable, and my iMac screen won't work, how to fix this?
I did the same thing. The pins are VERY easy to bend. I replaced it with a new cable from this company.
http://www.macpalace.com/922-9497-cable-...
Waiting for it to arrive.
Michael -
I wish this step was listed as a warning before lifting the monitor and as the first cable to undo. I broke it as it popped up and out, had to trash my Mac and I am stuck with a new hard drive.
Frank1701a - 返信
I followed the directions to a T and everything worked going back together. That cable in step 7 is delicate so one must be very careful.
Same problem for me. I damaged this cable and am ordering one now.
This is a tough step so I would also suggest removing this cable first.
lyleberman - 返信
Yes, damaged mine too. It is better to take it out of the LCD and install it carefully on the logic board, then install it to the LCD.
asle -
Ok finally got the cable and was able to successfully finish the project.
That video cable is ROUGH to install.
lyleberman - 返信
The same thing happened for me. That cable was by far the shortest and a slight pull of the display up caused the connector to come free. Luckily it wasn't damaged by this. It was pretty unclear to me how that connector fit in as well. It slides in and out parallel to the surface of the mother board, up towards the top of the iMac to unplug and down towards the bottom to plug in. I agree, if I were to do this repair again that is the first interior cable I would disconnect. Maybe a closeup of the cable plugged in and unplugged to show exactly how it engages and disengages would be good as well.
It is fine to remove the cable from the logic board when when you remove the screen. But when when assembling back together I found it better to take the LVDS cable out of the LCD and install it carefully on the logic board. Then connect it to the top of the LCD. Also the connector to the LCD is much more solid and not so easy to bend.
This is by far the best way round to do this as trying to refit the cable to the logic board is a complete nightmare.
Russ -
I agree with asle, manipulating the display end of the cable would be easier - at least it cannot be any harder then manipulating the motherboard end.
Jerry -
well I did all t these steps and now the iMac won't turn on at all. I guess the big cable is not connected to the board as it used to... Mac is out of warranty so it's going out the door. RIP
this part is not complicated if you understand at first how the lock works.. remove the lock is easy, reassemble the cable and connect it is very problematic because the space to work is very tiny, but if you are carefully, it should be not a problem . try to see some videos from youtube first!
This totally blows.. If you want to do this correctly and not destroy your computer over this step, - OWC’s video will show you EXACTLy what to do with the display cable ..
Don’t raise the display more than 3-4 inches. Pull the tape off the back of the display and unhook the cable from the display, instead of trying to remove it from the motherboard. As soon as I raised the display, the cable snapped loose. Ordered a new cable from Amazon. Am waiting to see if works ok.
The worst thing about the whole tear-down procedure, was the display data ribbon cable in this step. As others have noted, It popped out of its socket on the mother board while disconnecting the lcd. I didn’t get a chance to see exactly how it connected on to the moboard . I damaged the dainty and minute ribbon end while trying to re-connect it to the wrong side of the receptacle. Duh! I feel so stupid. :(
I had to order a new ribbon cable ($14) . Luckily, i was able to plug new ribbon into the fragile moboard connector adequately, and then the lcd end, during re-assembly. This re-assembly step is made for a very small person with extremely small hands and big eyes (like someone out of Gulliver’s travels).
2010 iMac SSD kit from OWC. Their video does not adequately explain the difficulty of re-installing the display port ribbon cable into the logic board. The best procedure would be to follow asle (see prior comment 8/11/15). The problem is exasperated by the fact that the plug into the LCD is covered in tape.
Disconnect the LCD thermal sensor cable connector from its socket on the logic board.
Be very careful - this connector very difficult to disconnect, and you have a high risk of pulling the cable pins out of the connect. If you have disconnected the 3 other cables, you can have a helper rotate the screen out of the way while you remove the hard drive.
Brian Tsai - 返信
I found this connector impossible to remove
I also found this extremely difficult to remove. Tiny cable with a death grip. I tried using two spudgers, my fingernails, and walking it out. In the end, I used two spudgers and pried it up, using leverage from the clip to the right.
Also, i recommend setting the iMac upright for this. I rested the screen on my chest while I dual wielded my spudgers.
eer ist zerbrochen! hoffe krieg ihn dann trotzdem wieder rein
This was connector was impossible to remove. Like a previous commenter, I did this with the machine upright and with the LCD Panel resting on my upper chest. Ultimately, the pins pulled out of the socket! Once they were out, it was relatively easy to remove the socket. I completed the drive replacement, (installed a 1 TB SSD) and then replaced the pins in the socket and reassembled the machine. One mental error I made was I couldn’t remember the correct orientation for the Black and White wires in the socket. In looking at the photos here on iFixIt, it looks like I reversed their orientation. However, the machine seems to be running fine. I installed macos High Sierra and migrated my data from my old HD and the machine has been running for two days now. I would hate to have to go back in and remove the socket and reverse the wire orientation. Anyone have advise on this?
In followup to my previous post, I launched TechTool Pro 9.6.1 and ran the Sensors Test. All Sensors tests were passed. These included:
LCD Proximity, LCD Thermal Compensation 2, LCD Proximity, Thermal Compensation. Machine seems to be running fine.
jmaher -
Remove the following four screws:
One 9.3 mm T10 Torx screw with a large head
Three 9.3 mm T10 Torx screws with a normal sized head
Pull the optical drive thermal sensor connector toward the top edge of the iMac to disconnect it from its socket on the logic board.
No need to do this! Just gently pull up the felt-pad sticky on top of the thermal sensor (looks like a tiny circuit board), then (again gently) peel the thermal sensor off the ODD. Leave it hanging while you remove the ODD and replace it with the SSD, then just put the thermal sensor covered by the protective felt-pad back onto the SSD enclosure.
cdansmith1 - 返信
I agree with cdansmith1, above.
I had removed the sensor completely. Booted up and the fan was like a jet engine - 4200rpm! I opened up the mac again to check the LCD thermal sensor cable was connected properly (as warned in Step 8). It was.
So, I simply used the spudger to peel off the felt sticky pad from and then the optical drive sensor too from the drive I'd taken out. Stuck the sensor onto the SSD using the same sticky pad, plugged it back into the original socket. Bingo. Booted up and everything was back to normal.
Lift the inner edge of the optical drive and maneuver its connector past the GPU frame attached to the logic board.
Carefully pull the optical drive off its mounting pins on the right side of the outer case to gain clearance for disconnecting the optical drive cable.
Allow the optical drive to hang down as you de-route the optical drive thermal sensor connector from behind the GPU heat sink.
this part is complicated because the wire is very delicate. when you try to extract it passing through the others elements this wire trap it very easily on the other elements of the logic board
Remove the single 13 mm T10 Torx screw securing the optical drive fan to the outer case.
Pull the optical drive fan connector out of its socket on the logic board.
Remove the optical drive fan from the iMac.
In the proceeding steps, you will disconnect the following cables:
SD Board and microphone
Left/Right Speaker
Wi-Fi Antenna
Bluetooth/Ambient Light Sensor/Camera/Left Temperature Sensor, Hard Drive Temperature Sensor and Hard Drive Fan
CPU Fan/Ambient Temperature and Power Button
IR Sensor
Be careful, reinstalling the logic board, some of these cables stand under the card and you have to remove the card again to get them… :((
One 9.3 mm T10 coarse-threaded screw
One 25 mm T10 coarse-threaded screw
Two 22 mm fine-threaded screws
Pull the upper right and lower left corners of the power supply away from the rear case to dislodge the mounting posts attached to the power supply's corners.
No need to do this if you’re just going to pull out the logic board for GPU replacement.
Carefully lift the power supply out of the outer case and rotate it to expose the cable lock as shown, minding the DC-out and AC-in cables still attaching it to the iMac.
Disconnect the DC-out cable by depressing the locking mechanism on the connector while you pull the connector away from its socket on the power supply.
Once the locking mechanism has cleared the socket, pull the DC-in connector away from the power supply.
Slightly pull the logic board away from the back of the outer case, then lift it upward to clear the lower front face of the outer case.
Remove the strip of tape securing the GPU thermal sensor cable to the logic board.
Remove the four 6.5 mm T8 Torx screws securing the GPU heat sink to the GPU.
It may be necessary to use a #1 screwdriver to hold the sockets on the GPU heat sink stationary as you loosen the T8 Torx screws.
Remove the GPU from the GPU heat sink.
Too late.
This image is very misleading : (
Please make this a warning, tell about the pads in the description and/or use a better picture!
My card is probably gone.
Did you find the thickness?
I am using pads with a 1.5mm thickness made by Arctic (color blue).
anyone has measure the gap? for me is 1mm, so the thickness of the pad. I have not tryed yet
Finally I used 1mm thermal pads. they worked well. First I bought 2mm pads and they definitly doesn´t fit, they don´t let the GPU micro not reach the heat sink (very bad). As Dan Packard suggest, I did not test 1.5mm pads, they are very expensive here in Argentina.
63 の人々がこのガイドを完成させました。
20 件のコメント
Hi everyone,
Which GPUs can you use as upgrades for this 2010 model? Mine has a Radeon 5670 512mb and I'd like something a bit more powerful...
Thanks!
Tom Edkins - 返信
lucky, i have a 256 mb card
Heh. I just replaced the 512mb 5670 card with the 256mb 4670 card.
Why, you might ask? Because of Mojave support. The 4670 is supported under Mojave but the 5670 is not…
One question:
i can put this GPU: NVIDIA GeForce GTX460M
on my iMac Mid 2011?
or i will have problems with the Drivers?
Wonderful guide! First time I opened a imac.
I need to replace the LCD cable connector on the motherboard. It is broken and it caused a short circuit on the motherboard. On the motherboard, underneath the grafic card, I've found a fried SMD inductance (L9000 on the motherboard) in the powerline of the grafic card. I restored the powerline with some solder leaving the inductance out. Should be no problem.
Graet,
I am very thankfull.
My first time I opened an iMac as well. Exciting!
And your superb instructions helped me to successfully remove the GPU.
Thank you so much!
Now I am looking for a compatible new one. Tips anybody?
Hello,
I have already recieved my GPU. I've installed it correctly, but it seems that there's a problem. It turns on, I hear the mac sound, I SEE the apple on white blackground, I see a state bar going bigger, but, when it achieves a 25% more or less, it shows a black screen with some coloured squares (some times) and then a whote screen. I hear the HDD and it seems that the Bluetooth keyboard works.
I have tried to reset the PRAM, I have removed and re-installed the ROM's 3V battery to reset it, but it doesn't change anything. What should I do?
Thanks.
Thanks!
With your Guide I replaced successfully the ATI Radeon HD 4670 with 256 MB of GDDR3 SDRAM in my iMac.
I took photos of every step, so i have no problems with the rebuild after the GPU replacement.
Hello! First of all, thank you for this wonderful guide.
I had my GPU (ATI Radeon HD 4670 256 MB) repaired and I put it back following the instructions. It does work, but the problem is that I only can start my computer by using the Safe Mode. If I try to start it normally, I have a green screen, with the apple in the middle and a status bar that never ends. I contacted the guy who reballed the GPU, but he doesn't know how to fix it at all.
Has anybody had this problem? Does anybody know how to fix it?
Thanks a lot.
Bad Reball. We do reballing in Spain and it's a signal of bad Reball or defective Graphic Chip. It do a reflow intead of a reballing? It check if the board is flat? It's a common issue with the graphic cards (At least in laptops)
Mine was sticking half way through startup and only starting in safe mode. When I removed the Radeon graphics drivers from the system/extensions folder, it started up and was usable as a short term fix - a bit like a car in limp home mode.
THanks for the guide it is great!! I replaced the GPU with a card that supposed to good on ebay... but it is only giving me a black screen when I boot the machine up!! I contacted the seller as I suspect he sent me a faulty GPU... it has the same Apple Part number so I know it's the right part... is there something else I need to do to make this work ? Any tips would be greatly appreciated!
Thanks
Superb guide - I think I may have broken the socket at Step 12, and needed a new logic board, so would stress the need to be extremely careful here (and read ALL instructions and notes first!), but overall an excellent walkthrough and way better value than buying a new imac. Thanks.
Thank you. This guide was awesome. I had a shop diagnose that I had a bad graphics card for free and suggest the machine was a throw away. Followed these instructions, did the oven bake 285F for 8 minutes on the card, got some thermal paste, put it back together and bing, it’s working again. Much appreciated!
Worked like a charm!
only problem: when reassembly, had to take out logic board two times to readjust cables (Step 23. Microphone cable + Step 29 blutooth/lightness/left thermal sensor). Special mentions on tricky positions would have been helpful.
Other then that, GREAT"!
Excellent directions and illustrations! I was getting a black screen on both the main monitor, and no video on external monitor plugged into min-display port. Rather than replace the gpu, i elected to clean the video card and then bake it in the oven at 380f for 8 minutes. More about this on Evan’s creative YouTube video explaining exactly how to do, https://youtu.be/9vPM41ZmLos
The ribbon cable connection to the socket on the moboard is a real ##&&% as people have commented in step 12.. It’s a miracle my iMac works again. The display now looks terrific!
I just wanted to thank you for this guide, but at Step 49, at this line:
“Remove the four 6.5 mm T8 Torx screws securing the GPU heat sink to the GPU.”
The Torx screws actually ended up being T9 for me, because my T8 had too much play.
So either this needs a correction or the screws vary by model.
Before beginning unplug your iMac.
Henry Barnett - 返信
The screws are not phillips #1 as implied above. My phillips#2 bit fit.
John McWilliams - 返信
Yes phillips #2 is the correct Bit
Heath - 返信
