メインコンテンツにスキップ
iMac Intel 21.5インチEMC 2308電源ユニットの交換
必要な工具と部品
  1. iMac Intel 21.5インチEMC 2308電源ユニットの交換, ガラスパネル: 手順 1、 2の画像 1 iMac Intel 21.5インチEMC 2308電源ユニットの交換, ガラスパネル: 手順 1、 2の画像 2
    この手順で使用する道具:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    購入する
    • 作業を始める前に、iMacの電源を切り、画像のように本体を倒して、柔らかい表面上に載せてください。
    • ガラスパネルの上部コーナーの2箇所に吸盤カップを取り付けます。
    • iFixitが販売している吸盤カップを取り付けるには、まず吸盤カップの持ち手ハンドルをガラスパネルの表面に対して水平になるように上げてください。ガラスに吸盤カップを軽く装着して、もう一方のハンドルも平行になるように上げてください。
    • 吸盤カップがうまく装着しない場合は、ガラスパネルと吸盤カップを中性洗剤などで綺麗に拭き取ってください。
    Very easy to lift the glass out. Don't jerk too hard.
    kctipton - 返信
    Another comment on DATA & LCD Temp. Sensor cables: I had to remove the vertical sync, and the backlight cable, however, if you have an assistant or/can carefully rotate the screen clockwise/and then have it held up about 5" to 6" at a slight angle, you do not need to remove LCD data cable or LCD thermal cable, however - IMPORTANT: you must have a second pair of hands/or way to securely prop up the LCD. Also, don't rotate too much, since then you will pull out LCD data cable, and it renders the whole exercise moot, or can damage the cable or connector.
    MaximBorzov - 返信
    You don't need suction cups. The screen, held by magnets, can simply be pried off using a very thin blade such as a screw driver and fingers.
    Deepsurvival - 返信
    That's a bad idea. using a metal tool to pry off glass is likely to end with an expensive broken front glass.
    Suction cups are common. Find a couple and do it the safe way. I use some cheap ones that came with iPhone repair kit.
    max damage -
    No need for suction cups, I just stuck my nails (short like guys usually have) between the top part of the screen and body, and it came off easily. I've never done it before, so it seems to be very easy.
    Nikolas Lintulaakso - 返信
    Nails worked for me too
    Rob Dale - 返信
    Just completed the replacement of the optical drive with an SSD using an OWC Data Doubler kit. Attempted to remove the optical drive without disconnecting any cables but found it a bit fiddly to orient the screen for good access. I bit the bullet and disconnected them and found the process less daunting than I imagined. Reconnecting them was similarly straightforward if you're careful.
    Tip: you can skip the step for removing the optical drive thermal sensor connector from the motherboard. Still need to remove the sensor from the optical drive but you can leave that hanging and reattach it to the SSD later.
    osienna - 返信
    I use Garmin GPS suction cup. Work very well
    jc3Dcx - 返信
    I’ve just successfully installed a 1TB SSD in place of my optical drive thanks to the information here- thank you to everyone who has contributed!
    3 comments- the procedure described here seems to vary between HD replacement and dual HD/optical drive replacement. This can be confusing at times.
    Expect there to be minor differences between the layout described and what you find when you open up your iMac. There are also, surprisingly, differences between the HD enclosure description, and the article provided by ifixit.
    I was able to replace the DVD/HD enclosure single-handedly without fully removing the LCD, or deconnecting any of the cables (steps 5-11). It’s a bit cramped, and fiddly, but I was not happy removing any of the cables despite watching videos, etc., since they all seemed to involve applying more force than I was comfortable with. A more detailed description of how to release them might have helped, but even here, there may be minor variations even within the 2389 model.
    Good luck!
    ivan birks - 返信
    I did it several times with one suction cup at the end of a kitchen brush. Once with the blade of a swiss army knive, also ok. And i’m pretty sure it works with fingernails too
    Tai - 返信
    Fingernails are all you need to free the glass from its magnetic hold. If you don’t have them, slip something thin and plastic, like a spudger, at a top corner.
    Max Powers - 返信
    Minha dúvida é a seguinte: após o técnico trocar o HD do meu iMac de 21,5 polegadas, a câmera parou de funcionar. Seria por causa da troca do HD? Tem solução?
    Claudio - 返信
    Creio que o cabo da camera não foi plugado ou deu mau contato… ou até danificado.
    glecyo@gmail.com
    glecyo medeiros -
    I can’t get my glass to budge. I’m replacing a cracked one and now it’s about to shatter.
    jamboxmitchell - 返信
    I know that I'm replying really late but I advise to use clear tape over any cracks so the cracks don't get bigger
    Jace Holmes -
    Check for chips in the glass BEFORE you do this step. If there is a chip when you pull up with the suction cups you will wind up with a jagged mess. If you do have a chip I would advise covering the screen near the chip with clear tape of some kind before lifting out. Mine shattered right at the chip and the resulting glass dust cloud got all over. My solution was buying a new glass screen.
    BCam - 返信
  2. iMac Intel 21.5インチEMC 2308電源ユニットの交換: 手順 2、 2の画像 1 iMac Intel 21.5インチEMC 2308電源ユニットの交換: 手順 2、 2の画像 2
    • ゆっくりとガラスパネルをLCD表面に垂直になるように持ち上げて、スチール製のマウントピン
    • ガラスパネルをiMacの底側端から引き抜き、丁寧に脇に置いてください。
    • 再組み立ての際には、ガラスパネルの内側やLCD表面を綺麗に拭いてください。デバイスの電源を入れると、ほこりや指紋が内部に閉じ込められ、視界が遮られてしまうことがあります。
    What's the best product to clean the face of the LCD?
    Steve Speirs - 返信
    Microfiber Cloth
    Leonardo Fournier -
    Try your best not touch it in the first place
    Brian -
    Wearing Nitrile or regular surgical gloves helps prevent finger prints if you accidentally touch the glass.
    amiller770 - 返信
    I use a Swiffer duster from above at the last moment before I let the magnets grab the glass cover. This has worked so well the last dozen or so times I’ve replaced a glass cover since I never have access to a “clean room” and don’t wear a “bunny suit”.
    Also, more dust will shed from your skin if you’ve just taken a shower, so I like to finish these repairs in the morning before a shower.
    gatortpk - 返信
  3. iMac Intel 21.5インチEMC 2308電源ユニットの交換, ディスプレイ: 手順 3、 3の画像 1 iMac Intel 21.5インチEMC 2308電源ユニットの交換, ディスプレイ: 手順 3、 3の画像 2 iMac Intel 21.5インチEMC 2308電源ユニットの交換, ディスプレイ: 手順 3、 3の画像 3
    • アウターケースからディスプレイを固定している8 mm T10トルクスネジを8本外します。
    • 最後の2枚の画像はディスプレイ両側の詳細です。
    On reassembly, it is REALLY HARD to align those screws, because of the field of the strong magnets that hold the glass cover on. I'm sure there's a trick to it, but I'd love to know what it is for future reference.
    Peter Shenkin - 返信
    I used needlenose pliers and the T10 to align the screw into the hole. Otherwise the screw keeps jumping to the magnet. And patience with this NON-CAPTIVE screw design (c’mon Apple, even **I** came up with that, and I’m an idiot!)
    finnik2d - 返信
    A short piece of small gauge vinyl tubing that fits tightly over the head of the T-10 driver leaving an 8th of an inch or so in which to insert the screw to engage the head will hold the screw long enough to keep it away from the magnet and get it going in the hole.
    Paul Boudreau - 返信
    I use non magnetic SS curved tip tweezers together with a magnetized #10 torx bit both to remove and reinstall the screws. You can magnetize and demagnetize the bit using the strong magnets on the LCD frame. Don't worry too much during removal, you can recover the screw. But loath the moment you drop the last screw during reassembly. For that reason, reinstall the screws near the magnets and hardest to get to first.
    Michael Ben-Yehuda - 返信
  4. iMac Intel 21.5インチEMC 2308電源ユニットの交換: 手順 4、 1の画像 1
    • アウターケースからディスプレイ上部端をわずかに持ち上げます。
    • あまり高く持ち上げすぎないでください。ロジックボードとディスプレイは数本のケーブルで繋がったままです。
    When putting the display back I have resistance from the foam elements (on the top end where the iSight is) and have to press down really hard. Is that okay?
    gm.konsortium - 返信
    Well, stupid me put the 3.5" to 2.5" cage the wrong side up. ;)
    gm.konsortium - 返信
    Standing the imac upright on its stand really helps this step! Laying it falt makes getting under the panel a real hassle.
    finnik2d - 返信
  5. iMac Intel 21.5インチEMC 2308電源ユニットの交換: 手順 5、 3の画像 1 iMac Intel 21.5インチEMC 2308電源ユニットの交換: 手順 5、 3の画像 2 iMac Intel 21.5インチEMC 2308電源ユニットの交換: 手順 5、 3の画像 3
    • iMacの左上隅付近にあるLEDドライバボードのソケットから垂直の同期リボンケーブルを引き出します。
    • 垂直の同期リボンケーブル端はZIFになっていますが、ソケットにはロックや固定フラップが付いていません。 ケーブルをソケットからiMacのオプティカルドライブ側に引き抜いて、LEDドライバーボードから外します。
    The vertical sync cable was snug initially and now is loose. I checked and the cable is intact. Has anyone had experience with making it fit better?
    Rajan - 返信
    Scotch tape on the upper side and sliding this in helped to secure the cable.
    Rajan - 返信
    Reassembly of this part was the closest I came to disaster on this project. I tried inserting the connector a few times without success, and when I looked it it the leads, which are fragile, were all mangled. I smoothed them out by hand as best I could and and reinserted, very carefully this time. The trick is that the tip of the connector should be pointed somewhat upwards when reconnecting.
    I was pretty sure that when I was done, I would reboot but have no display; but fortunately, everything worked.
    Peter Shenkin - 返信
    Hi, I still have a question. What is the "Job" of the vertical sync ribbon cable. Thanks
    Lutz Blum - 返信
    So let’s say someone wanted to suck some of the dust off the back of the display before reassembly. Let’s just say that. Someone would likely suck this forsaken cable up into the vacuum tube then, wouldn’t they? They might. And if it were to oscillate in a rushing torrent of air, it might get munged? It might.
    Here’s how you overcome such a disaster:
    1) cut the end fresh, as close to the end as you can while cutting off any frayed end.
    2) abrade the end gently, repeatedly, along the connector wire axis. I used emory paper. Your goal is to expose the copper conductors in the last 1/4” of the fragile evil wire.
    3) Tape a small stiff cardstock to the back of the end of the connector. This is essential to press the connector wires into the connector.
    4) Gently insert, taking special caution to not peel the copper off of the connector.
    5) Tape that connector down deftly, without letting it move a millimeter and securing it for all time.
    sydnius - 返信
    I just leave it connected. After disconnecting the other cables, there is enough slack to lay the display on its backside if you’re working on a flat surface.
    Duane Johnson - 返信
    I have replaced the hdd in this model about 8-10 times - I have never had to disconnect any cables other than the sata and temp sensor cables on the hdd. I just prop the lcd up with an egg carton (or something about 3 inches high that is soft and light) and access the hdd that way. The only thing I ever have trouble with are is putting the LCD screws back in around the magnets - but I have pretty much perfected that with a sissor/ tweezer tool.
    Suzanne Levy - 返信
    Could you put up some photos of this procedure - egg carton etc…
    Peter Barnett -
    Any ideas where to replace this cable?
    Danny Shaw - 返信
    I followed Suzanne’s comment and also did not disconnect this cable (vertical sync ribbon cable) to avoid damage. I pivoted the screen about 110 degrees after the other cables where detached. On a flat surface, this is easily done and the cable is not tight. Image of my angle if I can drop a link. and cable in this position not in tension.
    investments kkl - 返信
    Where can I buy the replacement for this vertical sync replacement cable?
    Neil Gonsalves - 返信
  6. iMac Intel 21.5インチEMC 2308電源ユニットの交換: 手順 6、 3の画像 1 iMac Intel 21.5インチEMC 2308電源ユニットの交換: 手順 6、 3の画像 2 iMac Intel 21.5インチEMC 2308電源ユニットの交換: 手順 6、 3の画像 3
    • LEDバックライト電源ケーブルをLEDドライバボードから接続を外すため、ディスプレイをアウターケースから外します。
    • コネクタをソケットから引き離しながら(iMacの下端に向かって)ロック機構を押し下げて、LEDバックライト電源ケーブルの接続を外します。
    I found it easier to very slightly lift the front edge of the black connector with a small spudger, then gently pulling away towards the bottom of the iMac. Pressing felt a little crude and didn’t work for me.
    Anthony C Carnell - 返信
  7. iMac Intel 21.5インチEMC 2308電源ユニットの交換: 手順 7、 1の画像 1
    • ロジックボード上のソケットからディスプレイデーターケーブルコネクタの接続を外すため、2つのコネクタケーブルのアーム両側を掴みます。
    • ディスプレイデータケーブルのコネクタを、ロジックボードのソケットから引き抜きます。
    • このケーブルは簡単にダメージが入ってしまうため、ケーブルの接続を外す時、再接続するときはご注意ください。
    in Step 7, my connector (new 21.5 iMac - Dec 2010) was not attached that way and just came of easily.
    erin - 返信
    Aperte as duas exibição do conector do cabo de dados braços juntos para desbloqueá-lo de seu soquete na placa lógica.
    Darlan Perira da Silva - 返信
    I accidently broke the data cable socket on step 7. Any advice on what i should do?
    Sam Tang - 返信
    I feel pretty silly. I spent wayyyy too long trying to get these cables disconnected. Happy I found this guide; hopefully, I won't struggle with such simple things since you provide pretty good details! Thanks.
    J.w. - 返信
    Pas beaucoup de place pour déconnecter ce cable ! En essayant d'ouvrir trop l'écran pour passer mes "grosses mains" j'ai cossé le connecteur : je suis dans le caca :-( (et pourtant j'en fait des démontages !) Alors ATTENTION !!!
    divers - 返信
    Il vaut mieux déconnecter la partie du côté écran en premier (sous l'autocollant noir)
    divers - 返信
    Je suis d’accord. C’est plus facile. Merci mon ami
    Anthony C Carnell -
    Translation: It is better to disconnect the screen side first (under the black sticker)
    Michael Seiler -
    ALWAYS ALWAYS ALWAYS REMOVE THIS CABLE!!! Even if you are "only in there for a minute" tearing the connector off the board is EXTREMELY easy.
    DistroHopper39B - 返信
  8. iMac Intel 21.5インチEMC 2308電源ユニットの交換: 手順 8、 1の画像 1
    • ロジックボード上のソケットからLCDサーマルセンサケーブルのコネクタを外します。
    • 作業完了後に、ファンがフルスピードで回転している場合は、この接続またはハードドライブのサーマルセンサーケーブルを点検してください。
    This is important regarding the fan running full speed
    http://blog.macsales.com/19617-diagnosin...
    tobykirkland - 返信
    Is there a way to test the power supply to see if it's dead?
    professorminh - 返信
    Achtung! Dieser Stecker kann sehr fest sitzen, hier hilft ein guter Fingernagel um den Stecker abwechselnd rechts und links zu Hebeln
    bluesoundsmusic - 返信
    English translation of bluesoundsmusic comment: “Caution! This plug can be very tight, here a good fingernail helps to lever the plug alternately right and left”
    investments kkl -
  9. iMac Intel 21.5インチEMC 2308電源ユニットの交換: 手順 9、 1の画像 1
    • iMacの上部端に向けて、ディスプレイを丁寧に引き抜いてください。そしてアウターケースから持ち上げて取り出します。作業中、ケーブルが引っかかっていないか確認してください。
  10. iMac Intel 21.5インチEMC 2308電源ユニットの交換, 電源ユニット: 手順 10、 1の画像 1
    • アウターケースに電源ユニットを固定している次のネジを4本外します。
    • 22.2 mm T10トルクス細目ネジー2本
    • 25 mm T10トルクス並目ネジー1本
    • 9 mm T10トルクス並目ネジー1本
    • 次の2つの手順では電源ユニットの露出面に手を近づけます。 ボードに取り付けられた数々の大型コンデンサによる高電圧ショックを避けるため、電源ユニットの表面に絶対に触れないでください。
    Watch orientation of iMac in relation to this picture: if the base is AWAY from you, the screw positions are reversed in this picture. Also use the black power cable for position reference.
    finnik2d - 返信
    fuuuuuuuck shiiiittt dammn that mf hurt like !&&* fucckken shocker here guys this macpos WILL KILL your ass be &&^&^$^ aware
    Jeff Robison - 返信
    I installed the power supply and nothing happened when I pushed the power on button, has this happened to someone else or should I also replace the power cable?
    Jose Valdez Jr. - 返信
    Okay, is the side with the soldier joints or the side with the capaciters the “face?”
    Also, you need to destroy that little hook that keeps the big connector on unless you have three strong little hands. Don’t worry, it’s not going to fall off, you can still cut yourself trying to wiggle that thing off. Especially when you are holding the board by the edges to avoid the “face.”
    Gladephone - 返信
    I've taken out the logic board on a late 2009 iMac twice in the last two years, and in neither case did I need to remove the power supply. You can do the rest of the steps without removing the power supply, so I would suggest just making things simpler and leaving it in.
    Phil McInnis - 返信
  11. iMac Intel 21.5インチEMC 2308電源ユニットの交換: 手順 11、 1の画像 1
    • ゆっくりと注意しながら電源ユニットをアウターケースから取り出して、画像のように露出したケーブルロックを回しながら見えるようにします。 DC-OutケーブルはiMacに接続されたままです。
    • 電源上のソケットからコネクタを引き抜きながら、コネクタ上のロック機構を押し下げて、DC-In ケーブルの接続を外します。
    • ロック機構がソケットから解放できたら、DC-In コネクタを電源ユニットから引き抜きます。
    I found my DC-In cable VERY difficult to detach. I depressed the locking mechanism, but still needed to use my iFixit Jimmy to carefully, gently, slowly work the cable connector (male) loose and away from the power supply (female).
    Bryan Jensen - 返信
  12. iMac Intel 21.5インチEMC 2308電源ユニットの交換: 手順 12、 1の画像 1
    • ソケットからコネクタを引き抜きながら、ロック機構を押し下げて、AC-Inケーブルの接続を外します。
    • アウターケースから電源ユニットを取り出します。
    This was not easy to disconnect with one hand holding the power supply (being careful while holding just to be cautious against any possible electrical discharge). Note that the connector is not on power supply side but on AC-In cable side. Couldn't quite see well enough from photo shown, but hold on the AC-In side of cable connector (depressing the locking mechanism of the male side) and pull away from the Power Supply (female side) cable.
    Bryan Jensen - 返信
    i’ve gotten away with not removing the PSU at all when removing the motherboard. havent had any issues
    Akeem Scrubb - 返信
終わりに
デバイスを再組み立てするには、これらのインストラクションを逆の順番に従って作業を進めてください。
63 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
作成者
7人の作成者と共同で作成されました。
Andrew Bookholt
586,394 ポイント
619のガイドは作成済み
3 件のコメント
Thank you Andrew!
Glen Comstock - 返信
The Photo shows the hand right on th back of the board, which seems more than a bit dangerous. I would touch the board only at its corners therefore.
Chris Müller - 返信
Thank you Andrew.
Jonathan - 返信
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 40
過去 30 日: 128
今までの合計 43,334
