メインコンテンツにスキップ
iMac Intel 21.5" EMC 2308 Glass Panel Replacement
必要な工具と部品
  1. iMac Intel 21.5" EMC 2308 Glass Panel Replacement, Glass Panel: 手順 1、 2の画像 1 iMac Intel 21.5" EMC 2308 Glass Panel Replacement, Glass Panel: 手順 1、 2の画像 2
    この手順で使用する道具:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    購入する
    • Before beginning, unplug your iMac and lay it on a soft surface as shown.
    • Stick a suction cup near each of the two top corners of the glass panel.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
  2. iMac Intel 21.5" EMC 2308 Glass Panel Replacement: 手順 2、 2の画像 1 iMac Intel 21.5" EMC 2308 Glass Panel Replacement: 手順 2、 2の画像 2
    • Gently lift the glass panel perpendicular to the face of the LCD enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
    • Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
    • During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
終わりに
29 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Andrew Bookholt
586,606 ポイント
619のガイドは作成済み
2 件のコメント
how much dose it cost
yosef davidov - 返信
to fix 21 inch screen
yosef davidov - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 29
過去 30 日: 106
今までの合計 60,213
