メインコンテンツにスキップ
iMac Intel 21.5" EMC 2308 CPU Replacement
必要な工具と部品
  1. iMac Intel 21.5" EMC 2308 CPU Replacement, Access Door: 手順 1、 2の画像 1 iMac Intel 21.5" EMC 2308 CPU Replacement, Access Door: 手順 1、 2の画像 2
    • Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
    • These screws will remain captive in the access door.
    • Remove the access door from your iMac.
    • During reassembly, fasten the access door loosely and align it with the pocket cut into the outer case of the iMac before fully tightening the screws.
  2. iMac Intel 21.5" EMC 2308 CPU Replacement, Glass Panel: 手順 2、 2の画像 1 iMac Intel 21.5" EMC 2308 CPU Replacement, Glass Panel: 手順 2、 2の画像 2
    この手順で使用する道具:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    購入する
    • Before beginning, unplug your iMac and lay it on a soft surface as shown.
    • Stick a suction cup near each of the two top corners of the glass panel.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
  3. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 3、 2の画像 1 iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 3、 2の画像 2
    • Gently lift the glass panel perpendicular to the face of the LCD enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
    • Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
    • During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
  4. iMac Intel 21.5" EMC 2308 CPU Replacement, Display: 手順 4、 3の画像 1 iMac Intel 21.5" EMC 2308 CPU Replacement, Display: 手順 4、 3の画像 2 iMac Intel 21.5" EMC 2308 CPU Replacement, Display: 手順 4、 3の画像 3
    • Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
    • The last two pictures are detail shots of each side of the display.
  5. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 5、 1の画像 1
    • Slightly lift the top edge of the display out of the outer case.
    • Do not lift it too much. There are several cables attaching the display to the logic board.
  6. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 6、 3の画像 1 iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 6、 3の画像 2 iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 6、 3の画像 3
    • Pull the vertical sync ribbon cable out of its socket on the LED driver board near the top left corner of your iMac.
    • The vertical sync ribbon cable has a ZIF style end, but the socket has no lock or retaining flap. Simply pull the cable away from its socket toward the optical drive side of the iMac to disconnect it from the LED driver board.
  7. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 7、 3の画像 1 iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 7、 3の画像 2 iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 7、 3の画像 3
    • Rotate the display out of the outer case enough to disconnect the LED backlight power cable from the LED driver board.
    • Disconnect the LED backlight power cable by depressing the locking mechanism while pulling the connector away from its socket (toward the bottom edge of the iMac).
  8. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 8、 1の画像 1
    • Squeeze the two display data cable connector arms together to unlock it from its socket on the logic board.
    • Pull the display data cable connector away from its socket on the logic board.
    • Be careful when disconnecting and reconnecting this cable, as it is easily damaged.
  9. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 9、 1の画像 1
    • Disconnect the LCD thermal sensor cable connector from its socket on the logic board.
    • If your fan is spinning full speed after completion, check this connection or the hard drive's thermal sensor cable.
  10. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 10、 1の画像 1
    • Carefully pull the display toward the top edge of your iMac and lift it out of the outer case, minding any cables that may get caught.
  11. iMac Intel 21.5" EMC 2308 CPU Replacement, Power Supply: 手順 11、 1の画像 1
    • Remove the following four screws securing the power supply to the outer case:
    • Two 22.2 mm fine-thread T10 Torx
    • One 25 mm coarse-thread T10 Torx
    • One 9 mm coarse-thread T10 Torx
    • The next few steps bring your hands close to the exposed face of the power supply. To avoid a high voltage shock from the many large capacitors attached to the board, do not touch the face of the power supply.
  12. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 12、 1の画像 1
    • Carefully lift the power supply out of the outer case and rotate it to expose the cable lock as shown, minding the DC-Out cable still attaching it to the iMac.
    • Disconnect the DC-In cable by depressing the locking mechanism on the connector while you pull the connector away from its socket on the power supply.
    • Once the locking mechanism has cleared the socket, pull the DC-In connector away from the power supply.
  13. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 13、 1の画像 1
    • Disconnect the AC-In cable by depressing the locking mechanism while pulling the connector away from its socket.
    • Remove the power supply from the outer case.
  14. iMac Intel 21.5" EMC 2308 CPU Replacement, Optical Drive: 手順 14、 1の画像 1
    • Pull the optical drive thermal sensor connector straight away from its socket on the logic board.
  15. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 15、 1の画像 1
    • Remove the four 9 mm T10 Torx screws securing the optical drive to the outer case.
  16. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 16、 1の画像 1
    • Lift the inner edge of the optical drive and maneuver its connector past the frame attached to the logic board.
    • Carefully pull the optical drive off its mounting pins on the edge of the outer case to gain clearance for disconnecting the optical drive cable.
  17. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 17、 1の画像 1
    • Use the flat end of a spudger to help disconnect the optical drive cable.
  18. iMac Intel 21.5" EMC 2308 CPU Replacement, Optical Drive Fan: 手順 18、 1の画像 1
    • Remove the single 13 mm T10 Torx screw securing the optical drive fan to the outer case.
  19. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 19、 1の画像 1
    • Pull the optical drive off the pins attached to the outer case.
  20. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 20、 1の画像 1
    • Pull the optical drive fan connector away from its socket on the logic board.
    • Remove the optical drive fan from the iMac.
  21. iMac Intel 21.5" EMC 2308 CPU Replacement, Logic Board: 手順 21、 1の画像 1
    • Pull the left and right speaker connectors toward the right side of the iMac to disconnect them from the logic board.
  22. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 22、 1の画像 1
    • Disconnect the audio port cable by pulling its connector toward the right side of the iMac.
  23. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 23、 1の画像 1
    • Disconnect the AirPort cable by lifting its connector off the socket on the logic board.
    • Lift the connector perpendicular to the face of the logic board.
  24. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 24、 1の画像 1
    • Disconnect the following cables by pulling their connectors toward the top edge of the iMac:
    • Camera cable
    • Hard drive thermal sensor
    • Hard drive fan
    • Microphone
    • Disconnect the following cables by pulling their connectors toward the right edge of the iMac:
    • Ambient temperature sensor
    • Bluetooth cable
  25. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 25、 1の画像 1
    • Disconnect the CPU fan and power button by pulling their connectors toward the left edge of the iMac.
  26. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 26、 2の画像 1 iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 26、 2の画像 2
    • If present, remove the piece of tape covering the IR sensor connector.
    • Disconnect the IR sensor by pulling its connector toward the top edge of the iMac.
  27. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 27、 1の画像 1
    • Use your fingers to lift IR sensor assembly straight up out of the outer case.
  28. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 28、 1の画像 1
    • Remove the following six screws securing the logic board to the outer case:
    • Three 25 mm T10 Torx
    • Two 21.5 mm T10 Torx
    • One 7 mm T10 Torx
  29. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 29、 2の画像 1 iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 29、 2の画像 2
    • Remove the plastic ducts from the side of the LED driver board and the hard drive by pulling them away from the outer case.
  30. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 30、 1の画像 1
    • Carefully remove the aluminum tape attaching the GPU heat sink to the outer case.
    • It is not necessary to completely remove the aluminum tape from the GPU heat sink.
  31. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 31、 1の画像 1
    • In the following steps, you will maneuver the logic board out from the outer case. In doing so, be aware of the many cables still attaching the logic board to the outer case.
    • Be sure the logic board clears the plastic lower optical drive fan mounting pin before lifting it up, as it is easily snapped off.
  32. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 32、 1の画像 1
    • Carefully pull the logic board slightly away from the outer case.
    • While holding the board away from the outer case, rotate the board back and forth while lifting up to release it from the outer case.
  33. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 33、 2の画像 1 iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 33、 2の画像 2
    • Now that the lower edge of the board is free from the outer case, rotate the logic board toward yourself to expose its rear face.
    • The following connector has a tendency to stick in its socket. If so, insert a metal spudger into the gap between the connecter and its socket. Twist the spudger to separate the two components.
    • Carefully pull the optical drive connector away from its socket on the logic board.
    • Pull the connector perpendicular to the face of the logic board.
  34. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 34、 1の画像 1
    • Disconnect the DC-In cable from the logic board by simultaneously depressing the locking lever on the connector while pulling it away from its socket.
    • Remove the logic board from the outer case.
    • During reassembly of the logic board, pay attention to the position of the I/O connectors. When the board is back in the case, insert a USB or Thunderbolt cable into one of the connectors to align it perfectly.
  35. iMac Intel 21.5" EMC 2308 CPU Replacement, Heat Sink: 手順 35、 1の画像 1
    • Use a pair of tweezers to lift the heat sink thermal sensor connector straight up out of its socket on the logic board.
  36. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 36、 2の画像 1 iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 36、 2の画像 2
    • If present, remove the "Warranty void if removed" stickers covering one screw on either side of the heat sink.
  37. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 37、 3の画像 1 iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 37、 3の画像 2 iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 37、 3の画像 3
    • Remove the following six screws securing the heat sink to the logic board:
    • Five 6.5 mm T8 Torx
    • One 7 mm T10 Torx
    • It may be necessary to hold the socket with a Phillips screwdriver on one side of the board while you unscrew the Torx screw on the other side of the board.
  38. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 38、 1の画像 1
    • Lift the heat sink bracket off the logic board.
  39. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 39、 1の画像 1
    • Carefully lift the logic board off the heat sink.
    • If the two components appear stuck together, carefully pry them apart with the flat end of a spudger, being careful not to disturb any surface-mount components on the logic board.
    • Make sure to apply a new layer of thermal paste before reattaching the heat sink. Our thermal paste guide makes it easy.
  40. iMac Intel 21.5" EMC 2308 CPU Replacement, CPU: 手順 40、 2の画像 1 iMac Intel 21.5" EMC 2308 CPU Replacement, CPU: 手順 40、 2の画像 2
    • Carefully pull the CPU retaining bar away from the CPU socket.
    • Rotate the bar toward the center of the logic board.
  41. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 41、 1の画像 1
    • Rotate the CPU clamp away from the CPU.
  42. iMac Intel 21.5" EMC 2308 CPU Replacement: 手順 42、 1の画像 1
    • Carefully lift the CPU straight up off its socket.
    • Be sure your new CPU is properly aligned and seated before clamping it back down.
終わりに
30 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Andrew Bookholt
586,239 ポイント
619のガイドは作成済み
19 件のコメント
Hello I fixit.!
Hello a lot of congrats! for your site! is very very helpfully for Mac Users
so. i have a question please if you want to help me.!
i have an i mac 21,5 late2009
3,06ghz intel core 2 duo
i have an idea to change the processor to. intel core i5 3,3 Ghz core
can be compatible . on main board .
thanks a lot for your time
ioannis ioannis - 返信
These 21.5" (and 27") iMacs came with only either Core 2 Duo E7600 (3.06Ghz, 2 core, 65W TDP, LGA 775) or Core 2 Duo E8600 (3.33GHz, 2 core, 65W TDP, LGA 775), which are incompatible with any Core i5 as there are no Core i5's that were available on the LGA 775 socket these systems.
You might be able to upgrade to a Core 2 Quad Q9505S or Q9550S (2.83GHz, 4 core, 65W TDP LGA 775) which would provide 2 extra cores than the E7600/E8600 and work in the same socket but drop the max clocks to stay at the same 65W TDP power limit.
Technous285 -
I installed a Q6700 Core 2 Quad into my late 2009 Core 2 Duo iMac.
Sadly it is not working, only recognize 2 Cores instead 4 under Windows 7.
Booting in the lates Mac OS, it gives up Kernel panic.
Any advise?
Tim - 返信
The Core 2 Quad Q6700 is a 105W TDP processor and the 21.5" & 27" iMacs running the Core 2 Duo E7600/E8600 only support 65W TDP LGA 775 Core 2 processors. If you wish to upgrade from the Core 2 Duo E7600/E8600 to a Core 2 Quad in these systems; I would recommend wither the Q9505S or Q9550S - specifically the "S" on there as those are the 65W TDP versions of the 105W TDP Q9505 and Q9550.
Windows is only allowing 2 of the 4 cores of that Q6700 to run to fit within the TDP of the system (particularly by regulating how much power the CPU can draw), and MacOS is panicking as it doesn't know how to handle the 105W the Q6700 is asking for on a 65W system.
Technous285 -
Hello,
I'd like to upgrade the Core 2 Duo 3.06 CPU of my iMac 10,1 21.5". I already done the same operation in a white Core Duo iMac, being able to install the unsupported OS X 10.7. I'd like to do the same on the 10,1 but what CPU can I install? It seems that the i3, i5 or i7 are phisically different, am I right? And the user Tim report in being unable to make it work with a Core 2 Quad. So... what are the possibilities? Thanks!
Francesco Vacca - 返信
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 46
過去 30 日: 242
今までの合計 80,207
