はじめに
Use this guide to replace a broken Bluetooth board.
必要な工具と部品
この手順で使用する道具:Heavy-Duty Suction Cups (Pair)$14.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Use the flat end of a spudger to pry the Bluetooth antenna cable connector up off the Bluetooth board.
2 の人々がこのガイドを完成させました。
コメント 1 件
Seriously this is so incomplete! What about the cable that connects the Bluetooth to the logic board!?!??? Like this is so half way explanatory!
