はじめに
Replace a broken AirPort card to regain Wi-Fi connectivity.
必要な工具と部品
この手順で使用する道具:Heavy-Duty Suction Cups (Pair)$14.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Use the flat end of a spudger to pry both AirPort antenna cable connectors up off the AirPort card.
もう少しです!
終わりに
3 の人々がこのガイドを完成させました。
