メインコンテンツにスキップ
iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換
必要な工具と部品
  1. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換, ディスプレイアセンブリ: 手順 1、 1の画像 1
    この手順で使用する道具:
    iMac Intel 21.5" Cardboard Service Wedge
    購入する
    • ヒンジを外すと、iMacはバランスが取れなくなり、作業が難しくなります。iMac Service Wedgeがあれば修理作業は素早く、簡単ですが、なくても対応できます。
    • iFixitの梱包用ボックスを使ってウェッジ用サポートを作ることができます。こちらから組み立てガイドを参照してください。
    • iMacの作業を始める前に、コンピューターの電源を外して電源のキャパシタを放電するため約10秒間電源を押し続けてください。
    • キャパシタの鉛や、電源の裏側にある露出した半田付け接合部分に接触しないよう、特にご注意ください。基盤の端のみを持ってください。
    The wedge is an extremely tight fit for this model. I was worried that the amount of force needed to use it as shown might damage the stand, so I used it with the long side down instead. It worked fine that way and didn’t need anywhere near as much force to insert.
    roberttrevellyan - 返信
    Here’s a good YouTube vid on upgrading the RAM: Can a Normal Person Upgrade the RAM in the 2017 21.5" iMac?
    Dan - 返信
    Here are a couple tips from me:
    1) Expose the adhesive to extreme temperatures. I did this by transporting my iMac in my car, screen-down on a piece of cardboard on a cold February morning (in Chicago). When I went to pick up the iMac, the screen practically fell off the chassis. I would have been distraught by this if I hadn’t already planned this replacement. So it was a happy accident.
    2) Remember to expell the residual power from the power supply by pushing the power button while the iMac is unplugged. This does NOT guarantee it’s safe to touch, but when I accidentally brushed the solder and exposed capacitors, I didn’t get shocked.
    jerrid_foiles - 返信
    Instead of using the wedge, I placed the iMac faced up with the top side (web cam) facing me while I ran the pizza roller around. It worked out great!
    Sam Fung - 返信
    “All iMacs also come with a traditional hard drive” mine doesn’t!! it’s HDD bay is completely empty, no SATA cable or anything. I guess I’ll have to upgrade the PCIe SSD instead.
    Chris Hughes - 返信
    There is no replacement glass for this model, it is part of the LCD and impossible to remove or replace- the entire LCD has to be replaced unfortunately if the glass is cracked or damaged. You will have to Google search for a replacement. Also be careful with some of the lock tight tork screws as I broke one of my screw mounts taking one out.
    Phil Tesone - 返信
    I used this service wedge but also found it a very tight fit. The same stabilization can be achieved by using a big rolled up towel.
    Ernst - 返信
    While this is a good instruction guide, I recommend to also look at OWC’s instruction video about drive installation, before starting the exercise. Those install videos are very detailed and useful.
    Ernst - 返信
    Main advice: TAKE YOUR TIME with the pizza roller.
    Make several passes, until you really feel like there's no more sticker in the way. Stay away from the camera though (approx. 1inch / 2.5cm on both sides). This will reduce the work left with the plastic card. Adhesive is really on the edge of the screen so there is absolutely no need to go any further than the recommended 1cm / 3/8inch depth.
    Where are the sensitive parts?
    Facing your iMac, imagine you're looking at a watch. There are antennas on 1, 2 and 4 o'clock. Do not insert any metal piece there (nor anywhere else, btw). Other than that AND the screen cables underneath the camera, not much danger.
    Froggy Manny - 返信
  2. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 2、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 2、 2の画像 2
    • ディスプレイの左側の電源付近から、iMac開口ツールをガラスパネルと背面エンクロージャーの間に差し込みます。
    • iMac開口ツール上の回転軸を押し込んでもディスプレイの奥深くまで届きません。もし異なるツールを使用する場合、ディスプレイから9.5mm以上は差し込まないでください。それ以上深く差し込むと、アンテナケーブルに深刻なダメージを与えてしまいます。
    Don’t get too worried about starting exactly where the picture says. The glue is stronger in some parts so just start wherever is easier and then work slowly and patiently around in the direction shown.
    Richard Cook - 返信
    As this guide doesn’t cover replacing the adhesive strips, I found referring to the following was useful (noting that it’s not for the same model of iMac, so the modification they mention wasn’t necessary): iMac Intel 21.5インチ EMC 2544の接着ストリップの交換
    Alan Digby - 返信
    It is very easy to crack the glass in front of the LCD during this step. I used the guitar pick, maybe it was too thick… crack is just on the frame but anyway it is disappointing :(
    Nikolay - 返信
    This part of the exercise should be done with extreme patience. I took my sweet time with the opening tool, rolling it through the entire panel and enclosure gap over and over again, until I was very sure no parts were sticking together anymore. And when I thought I was I done, I decided to do it over again.
    Ernst - 返信
    You can "warm up" the adhesive before try to cut it with the tool using a hair dryer. Heat the edges for about a minute, keep moving it so you don't cause stress in the glass. Also the above note.. use the tool and then the cards. Do not use a guitar pick or other objects as the thickness will cause you to break the front glass, which is a bonded part of the display (expensive).
    Carl Schultz - 返信
    Merci pour ce conseil
    bry nicolas -
  3. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 3、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 3、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 3、 3の画像 3
    • ピザカッターのようにツールを使いますー隙間に沿ってスライスしながら、フォーム製接着剤を切り込んでください。
    • カット用の車輪の裏の持ち手をしっかり持って内側に押し込んでください。もし外向きに引っ張ると車輪がハンドルから外れてしまいます。
    • ツールをディスプレイの左側に沿って下側から上部に向けてスライスします。
    Erreur de traduction: "de bas en haut" et non de" haut en bas" sur le côté gauche de l'écran
    Moreau - 返信
    If re-opening a screen that was opened and re-attached using iFixit’s adhesive strips, I would strongly recommend heating it first with an iOpener, heat gun or hair dryer. 20 minutes after attaching with the iFixit adhesive I tried to open it again with the pizza slicer to fix something and cracked the screen on the left-hand side.
    plasticpool - 返信
  4. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 4、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 4、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 4、 3の画像 3
    • 左側コーナー上部周辺までスライスします。
    Ne pincez pas l’écran avec l’autre main. Vous exercez une pression inutile sur le verre et empêchez la roulette de couper le joint.
    phfoglia - 返信
  5. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 5、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 5、 2の画像 2
    • ディスプレイ上部左側から接着剤を切開します。
  6. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 6、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 6、 2の画像 2
    • ディスプレイ上部に沿って開口ツールをスライスします。
    • すでに切開した箇所も、接着剤が完全に切断されているか確認するため、複数回に渡って前後にスライドしてください。
    In this step can I cut along the display without make any damage to the front camera?
    arisnordico - 返信
    Hi! Actually - there is no need to cut the tape around the camera area - there is no tape to cut at all! And so, the way go is easy - just pass 10 mm to the left and to the right from camera and start cutting!
    P.S. Just did the whole procedure to replace a RAM and to add SSD on PSIe an hour ago! Seems to be different reading the instructions... you know - 2/10 and so on. But it's really not that hard, trust me. I'll give it 5/10.
    P.P.S. By the way there is one trick to pass the difficult steps. Any action which requires pulling smth (motherboard, speaker, power supply unit) from the narrow crack (or should i say - slit?) at the bottom of your Imac is really not so easy.
    And the trick is to first remove a thin metal stripe with some kind of insulation on it which held by 5 small (very small!!) screws at the bottom of your Imac. After you done it - it's easy to pull everything! Pay attention to the fact that one of this 5 screws at the center are more shortly than others.
    dv1977 - 返信
    I did all steps like this manuell but now the Display wont work only some colered strips are to see! Whats happend??
    Can anybody help me ? Maybe the connector cable is broken?
    djfanta - 返信
    Check both connectors, probably one of them not seated well
    pzhivulin -
    You can add a SATA SSD if you already have a PCIe SSD Factory?
    kaserlik - 返信
    If you're changing cracked EMC 2638 display to new assembly, there's two more steps:
    Step 24: Use the tip of a spudger to flip up the metal retaining bracket on the display data cable.
    Carefully pull the display data cable from its socket on the display assembly.
    Step 25: Use the tip of a spudger to unplug bracket of the thermal sensor small cable near display data cable.
    Carefully remove scotch tape covering thermal sensor. Using iSesamo or flat tip of the spudger carefully peel the thermal sensor away.
    pzhivulin - 返信
    omg - forgot to switch the termal sensor from the old display...
    now fan runs like crazy...
    Andrei Balotescu -
    The key thing is to never put any force on the opening tool when working through the tape. Just roll it back and forth with ease.
    Ernst - 返信
  7. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 7、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 7、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 7、 3の画像 3
    • ディスプレイ上部の右側コーナー周辺までツールをスライドしながら、接着剤を切開します。
  8. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 8、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 8、 2の画像 2
    • ディスプレイの右側に沿ってツールを上部から下側に向けてスライドします。
  9. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 9、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 9、 2の画像 2
    • ディスプレイ右側の下部まで開口ツールをスライドさせて、ここで作業を終えます。
    • ここでもう一度、ディスプレイ全体に沿って開口ツールをスライドさせ、接着剤をスライスできたか確認しましょう。
    Yes, do it many times to loosen the adhesive.
    Noah Ralston - 返信
    Would be good data to show the 3 areas (wifi antennas where the "tape" is larger and covers them. The rest of the "tape" is 1.4" and easy. Also after removing the display, be sure to remove the old "tape" from both the display and the rubber parts of the case. Use the spudger to start an end and it should pull off easily. Careful on the baackside of the display as you can scratch off the black paint/covering.
    Carl Schultz - 返信
  10. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 10、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 10、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 10、 3の画像 3
    • 開口ツールがディスプレイ上の接着剤の大部分を切断できても、ディスプレイはわずかにケースに装着されたままです。残りの接着剤から完全に乖離するため、プラスチックカードを使用してください。
    • iMacのフロント側を上向きにしてテーブル上に置いてください。
    • iMac右側の上部から、ディスプレイとフレームの間にプラスチックカードを差し込みます。
    • 9.5mm以上はプラスチックカードを差し込まないでください。内部コンポーネントにダメージを与えてしまいます。
    this step is extremely important NOT to stick in the cards too far….. doing so, you risk a 600 euro replacement as I experienced………
    Edgar Broekema - 返信
    I drew a 3/8” line on my cards with a marker first.
    Max Romano - 返信
    I’m reading this on the EU store, please change all measurements to cm/mm.
    Morgana Devina - 返信
    @ifixit The next batch of cards you create should have a line printed on the card 3/8” in from the edges. Would make a nice reference.
    Richard Giratd - 返信
    Here’s where OWC provides glass removal suction cups, which is a better solution than plastic cards.
    The suction cups help to easily lift the glass panel, without risking the damaging of any internal wiring that the plastic cards could cause.
    Ernst - 返信
    Better to remove stand wedge at this point? Can’t see from pics
    derekrobinson - 返信
  11. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 11、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 11、 2の画像 2
    • ディスプレイとフレームの間に隙間を作るように、丁寧にプラスチックを外側に向けてひねります。
    • ディスプレイのガラスに圧力がかからないように注意しながら、ゆっくりと動かします。約6mm程度の隙間ができれば十分です。
    This part must be done very carefully or you can damage the flat cable from display, despite it was under a iron cover.
    Cassio Machado - 返信
  12. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 12、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 12、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 12、 3の画像 3
    • 残りの接着剤を乖離させながら、iMacの上部右側コーナーからディスプレイ中央に向けてプラスチックカードをスライドします。
    • iSightカメラ手前で止めてください。これ以上進むとダメージを与えてしまいます。
    You don't need to do it like this, simply open the iMac bendidng the LCD completely and use the pizza cutter to remove the adhesive.
    Felix - 返信
    Using glass removal suction cups will avoid running this risk of damaging the camera (or any wiring).
    Ernst - 返信
  13. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 13、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 13、 2の画像 2
    • 接着剤が再装着するのを防ぐため、ディスプレイ上部右側コーナー付近にプラスチックカードを差し込んだままにします。
  14. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 14、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 14、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 14、 3の画像 3
    • 2枚目のプラスチックカードをiMac上部左側付近のディスプレイとフレームの隙間に差し込みます。
  15. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 15、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 15、 2の画像 2
    • ゆっくりとカードを上向きにツイストして、ディスプレイとフレームの間の隙間を広げます。
    • 反対側も同様に、接着剤が乖離するようにゆっくりとツイストします。ディスプレイのガラスに余分な圧力がかからないようご注意ください。
  16. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 16、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 16、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 16、 3の画像 3
    • プラスチックカードを中央に向けてゆっくりとスライドして、iSightカメラの手前で止めます。
  17. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 17、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 17、 2の画像 2
    • プラスチックカードを左側上部コーナーの裏側に差し込みます。
  18. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 18、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 18、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 18、 3の画像 3
    • コーナー付近に差し込んだ2枚のプラスチックカードを手に取り、ディスプレイとケースの間の隙間を広げるようにカードを外側に向けてツイストします。
    • もし接着剤が剥がれていない箇所がある場合はツイスト作業を止めて、どちらかのカードを使って接着剤を切断します。
    • フレームからディスプレイ上部を持ち上げます。
    • 約5cm程度以上は、ディスプレイを持ち上げないでください。ディスプレイデータケーブルやパワーケーブルが基板に接続されたままの状態です。
  19. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換, ディスプレイアセンブリケーブル: 手順 19、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換, ディスプレイアセンブリケーブル: 手順 19、 2の画像 2
    • コネクタにアクセスできるほどのスペースを作るため、ディスプレイを持ち上げます。しかし、ケーブルが伸びて、コネクタの接続部分にストレスを与えないように、持ち上げすぎないようご注意ください。(約15cm程度が目安)
    • ディスプレイを片手で持ちながら、もう一方の手でディスプレイパワーケーブルの接続を外します。
    It was difficult to remove this connection. I ended up having to gently pull-up vertically a little on the wire side to unsnap it about 1mm and then horizontally wiggle it out.
    delacrj2 - 返信
    I had a difficult time removing this connection. I had to lift the wire-side about 1mm before it unsnapped and then carefully wiggle it out horizontally.
    delacrj2 - 返信
    Can this cable be replaced? I am worried mine is damaged. I have no display after the screen fell and stressed the display flex cables following an SSD upgrade.
    Jeremy Brainard - 返信
    This step should be done with extreme caution and care, as this step 19 is not described in great detail (sorry, author).
    The first (most outward) cable will slide out by gently pulling it by its tabs. The second (inner) cable is more tricky, as the locking lever must be moved backward first, before gently pulling backward on the cable connector. The angled tweezers are useful here, to help lift that locking lever, because fingers are too big for this.
    Ernst - 返信
    be VERY careful and SLOW...take your time. These displays crack VERY easily when removing and they'll spider web on you. I've done probably 20 or so of these and cracked 3 being super careful.....ugh.
    Faslane - 返信
    I found the best way to unplug this display power cable was to use my right hand, and the fingernails of my index finger and thumb to grab the ends of the tabs on either side of the connector, squeeze, and pull the connector out gently.
    Phil McInnis - 返信
    i think the cable nearest the case edge is held in by friction and can be gently pulled, maybe with fingernails or a spudger. The next cable is held by a wire lever clip as described above it unlocks so the cable can be removed. These cables are also fiddly to re-insert, I didn't get one of them home and had no display after power-up, so at the end, don't re-seal the screen until tested.
    Peter Taffs - 返信
  20. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 20、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 20、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 20、 3の画像 3
    • 引き続きディスプレイを片手で固定しながら、ディスプレイデータケーブル上にあるメタル製固定ブラケットを裏返します。
    • ロジックボード上のソケットから、ディスプレイデータケーブルをゆっくりと引っ張ります。
    • ディスプレイデータケーブルのコネクタを、ソケットからまっすぐ引っ張ります。その際、マザーボードにダメージを与えないよう気をつけながら、ケーブルをマザーボードと並行にして引き抜いてください。
    Cannot seem to find a replacement cable for this, as I suspect mine is damaged. Can’t even find a part number. Anyone know what it might be?
    https://www.amazon.com/gp/product/B08TTL...
    That's the part I ordered for mine and it seems to work ok. I did make a point of contacting the seller and advising them of my requirement and they ensured I got the right part and it matches the description of the link. Bear in mind I bear no responsibility if yours does not work since I am just sharing what I did and what I ordered. Thanks.
    Jim Stanford -
    I also need that cable.
    cameronjpu - 返信
    It's a little difficult to tell... but looking at the connection to the logic board on the video data cable, are the pins faced up or down?
    On the display, same question since it appears you have to "twist" the cable during the reconnection step.
    Jim Stanford - 返信
    For this particular cable, take a good look before pulling on anything. Plug is locked on its socket with a bracket. You can lift this bracket by holding the small, flat black plastic handle that is attached to it. If you're struggling to grab it, use the end of the pizza roller handle to lift it, or the tweezers. Cable then comes off by pulling parallel to the main board.
    Froggy Manny - 返信
    How can I tell if either of this cable is bad? My iMac display won't turn on after reconnecting it. I'm using an external display and everything is working except for the iMac display. If I go to settings - display the built-in display is recognize. But again nothing shows up in the screen - not even the apple logo when turning it on.
    Carlos Sosa - 返信
  21. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換, ディスプレイアセンブリの乖離方法: 手順 21、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換, ディスプレイアセンブリの乖離方法: 手順 21、 2の画像 2
    • ディスプレイをほぼ垂直になるまで持ち上げます。
    • この時点で、ディスプレイの下部に沿ってヒンジのようにフレームにディスプレイを固定しているする接着剤のストリップがまだ付いています。 ディスプレイを数回上下させると、この接着剤を緩めることができます。
    The best way to remove the chin adhesive is to use the tabs at either end (there are two strips that run from each outside corner to near the centre). Carefully pull the tabs up and the strips should peel off.
    Advance Technical Service - 返信
  22. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 22、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 22、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 22、 3の画像 3
    • 必要に応じて、プラスチックカードを使って底側の接着剤ストリップを切開できます。
    • 下端ディスプレイの接着ストリップ片側の端にある小さなタブをつかみ、接着剤をiMac上部側に引き寄せて剥がします。
    • この手順をもう一方の接着ストリップでも同じ作業を繰り返し、取り除きます。
    • どちらかの接着ストリップが切断して取り出せない場合は、プラスチックカードを使って、残りの接着ストリップ片を切り取ってください。
    At step 21-22, releasing the adhesive strips from the bottom of the display, I noticed a tab on the outer end of each strip. Pull the tab to remove the whole strip, no need to mess around with the plastic cards!
    Instead of the plastic cards, use the flat end of a spudger. Use it as scraper. Be careful as there are antennas mounted on the inside edge of the frame on the right side (facing you), and the top right (facing you). The original adhesive strips are on those as well. - ECJ
    ECJohansen - 返信
    A little bit of hot air (eg. hair dryer) will help soften the adhesive. Use a piece of cardboard or equivalent if you want to avoid blowing hot air towards the electronics.
    Be careful to remove absolutely everything - any remainder will create a bump and prevent your screen from sticking back to the frame when reassembling.
    Froggy Manny - 返信
    Froggy Manny - 返信
  23. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 23、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 23、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 23、 3の画像 3
    • ディスプレイをフレームから持ち上げて、iMacより取り出します。
    • 片側からゆっくりと持ち上げて、残っている接着剤を剥がしてください。
    • ディスプレイの取り扱いは特にご注意くださいー重量があり、大きく、ガラス製です。
    • 接着剤が切開できたら、古い接着ストリップはディスプレイを固定するために再利用することはできません。このガイドに従って、接着ストリップを交換して、リアエンクロージャーとディスプレイを固定してください。
    Après l'étape 23, j'ai suivi les instructions de la vidéo intitulée: Upgrade RAM in a mid-2017 21-inch iMac without complete disassembly.
    Lien: https://www.youtube.com/watch?v=_k9I7N9B...
    J'ai pu upgrader la RAM en enlevant juste le ventilateur.
    Koala - 返信
  24. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換, 下部サポート・ブラケット: 手順 24、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換, 下部サポート・ブラケット: 手順 24、 2の画像 2
    • 下部にあるサポートブラケットを固定している5本のプラスネジを取り外します。
    • 4本の3.2ミリねじ
    • 1本の1.7ミリねじ
    • 予め、ディスプレイパネルを外した時に残った両面テープを剥がしておく必要があります。
    I would recommend that those trying this have the project tray to contain all of the screws.
    Mikkif - 返信
    2 notes for reassembly, carful with screws not to strip the heads as they are really really small, make note to cut a gap in the the adhesive over the whole for the microphone.
    I managed to strip the head of one of the screws when putting it back in. So be carful with them when putting in / taking out. If you strip it on the way out you will need to take a fine drill and rill it out. Going back in, well as long as you never need to strip it down again not a problem.
    The second problem is a real pain, you need to make sure to cut a gap in the adhesive just to the right of Center at the button to allow for the microphone opening. If you don’t, the adhesive tape will stop any real pick up on the Mic, so you just need to cut a small gap in it before putting on the screen. Unfortunately I didn’t find this out (or do my checked before sticking it all back down, so have to pull screen back off and reapply new adhesive with a cut out in it at an other time.
    Andrew Taylor - 返信
    Refer her for more info on the mic / adhesive work around —> Muffled Microphone - iMac 21.5" (mid 2017) - Following Adhesive Strips
    Andrew Taylor - 返信
  25. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 25、 1の画像 1
    • iMacエンクロージャーから下部サポートブラケット(別名:顎ストラップ)を取り外します。
    Keep this long, aluminium part very straight when pulling it away or you might bend it
    Froggy Manny - 返信
    que pasa si no coloca esta pieza?
    CARLOS - 返信
  26. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換, ハードドライブブラケット: 手順 26、 1の画像 1
    • iMacにハードドライブブラケットを固定しているT10トルクスネジを外します。
    • 21 mm ネジー2本
    • 9 mmネジー1本
    • 27 mmネジー1本
    At step 26, when reassembling, it's super easy to over-tighten the 9mm screw and strip the brass ferrule out of its hole in the plastic bracket (%#*@).
    Mine has 4 different length screws, the two red colored 21mm screws in this guide are actually two differ lengths
    anonymous 523 - 返信
    Mi imac does not have a HDrive whats the steps to follow?
    Charlie - 返信
    buongiorno, l'imac del 2019, non monta alcuna ssd, ma monta una m2 direttamente sulla scheda madre!
    pertanto nella guida andrebbe aggiunto il cavo sata con sensore temperatura da aggiungere sulla scheda madre, per poter collegare un nuovo hd ssd altrimenti rimarrete come me bloccati con un imac aperto e non assemblato, in attesa di ricevere il cavo acquistato su internet da amazon o terze parti.
    vi consiglio inoltre di aggiungere una foto reale del ò'imac 2019 nella guida in cui manca l'ssd, renderà subito la problematica che avranno in molti!
    Donato Altomare - 返信
    Hi, mine doesn’t HAVE an HD/SSD to remove, the bay is empty (yes it was fully working yesterday. So what do we do ? I see someone else with the sane issue above….
    Jeroen Speak - 返信
  27. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 27、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 27、 2の画像 2
    • iMacから左右のハードドライブブラケットを外します。
  28. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換, 電源ユニット: 手順 28、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換, 電源ユニット: 手順 28、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換, 電源ユニット: 手順 28、 3の画像 3
    • 次の手順では、電源ユニットの露出面に手を近づけます。 電源ユニットの表面または露出したはんだ部分に触れないでください。触れてしまうと、ボードに取り付けられた多くの大型コンデンサからの高圧ショックを受けてしまう危険性があります。
    • スパッジャーの先端を使用して、電源ボタンケーブルコネクタの両側を押し、ソケットからゆっくりと引き出します。
  29. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 29、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 29、 2の画像 2
    • スパッジャーの先端を使用して、電源制御ケーブルコネクタの両側を押し、ソケットからゆっくりと引き出します。
  30. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 30、 1の画像 1
    • リアエンクロージャーに電源ユニットを固定している7.2 mm T8トルクスネジを2本外します。
  31. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 31、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 31、 2の画像 2
    • 電源ユニットで作業するときは、電源ユニットの背面にあるコンデンサのリード線や露出したはんだ接合部に触れないよう、くれぐれもご注意ください。 ボードの端のみを扱ってください。
    • 電源ユニットを前向きに傾けます。
  32. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 32、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 32、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 32、 3の画像 3
    • リアエンクロージャーから電源ユニットをわずかに持ち上げて取り出します。
    • 右側を左側より約2.5cm高く持ち上げたまま、電源ユニットを反時計回りに回転させます。
  33. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 33、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 33、 2の画像 2
    • 電源ユニットを右にスライドさせて、背面エンクロージャーのネジポストを露出させます。
  34. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 34、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 34、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 34、 3の画像 3
    • 電源ユニットを前向きに揺り動かして、リアエンクロージャーの角から電源ユニットを取り出します。
    • iMacから電源ユニットをまだ完全に取り出さないでください。ロジックボードにまだ接続されたままです。
  35. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 35、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 35、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 35、 3の画像 3
    • コンデンサのリード線や電源ユニットの背面にあるはんだ接合部の露出面に触れないように、くれぐれもご注意ください。 ボードの端のみを扱ってください。
    • 露出したはんだ接合部がメタル表面に接触しないようにしてください。接触してしまうと、ショートしてしまう可能性があります。
    • 電源を裏返して、ロジックボードの背後にあるDC電源ケーブル接続にアクセスします。
    • ケーブルの接続を外すには、ロジックボードの裏側にあるコネクタの裏側のリリースクリップを摘んで、コネクタをまっすぐ引き出します。
  36. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 36、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 36、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 36、 3の画像 3
    • 次の2つの修理ガイドの作業をする際は、iMacの背面を下に置くと便利です。
    • スパッジャーの平らな端を使用して、ACインレットケーブルコネクタの内側に付けられたリリースクリップを内側に押します。
    • スパッジャーでリリースクリップを押しながら、ACインレットケーブルをつかみ、コネクタをソケットからまっすぐ引き出します。
    I didn't bother to remover the power supply lead in this stage but simply flippedthe circuit board over onto the lower body of the iMac (NOT placing it directly onto the metal but onto a sheet of plastic)
    Fettler - 返信
  37. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 37、 1の画像 1
    • iMacから電源ユニットを取り出します。
  38. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換, ファン: 手順 38、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換, ファン: 手順 38、 2の画像 2
    • ロジックボード上のソケットからファンケーブルコネクタをゆっくりと引き抜きます。
  39. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 39、 1の画像 1
    • リアエンクロージャーにファンを固定している10mmのT10トルクスネジを3本外します。
    • 最上部のネジには、ディスプレイを支えるためにヘッドに接着されたゴムスタンドオフがあります。ーこれはそのまま残しておきます。
  40. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 40、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 40、 2の画像 2
    • iMacからファンを取り出します。
  41. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換, ハードドライブアセンブリ: 手順 41、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換, ハードドライブアセンブリ: 手順 41、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換, ハードドライブアセンブリ: 手順 41、 3の画像 3
    • ロジックボードに一番近い端からハードドライブを持ち上げて、角からわずかに引き出します。
    • ハードドライブは1本のSATAパワー/データケーブルによって繋がれています。この段階ではまだiMacから完全に外さないでください。
    The newer drives have rubber ends and an adhesive side, be careful removing them if replacing the drive and be sure they are securely pushed back into the holder
    Carl Schultz - 返信
  42. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 42、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 42、 2の画像 2
    • スパッジャーを使って、大型のプラスチックコネクタをゆっくりと押しながらハードドライブから離して、単一のSATA電源とデータコンボケーブルを外します。
    When reconnecting the SATA cable, there is nothing to make the connector hold still, and it is hard to reach, so it took several tries. I ended up taking off the rubber baby buggy bumpers to get more room, and then jamming them back on after getting the SATA connector snugged up.
    bstaud - 返信
    If by rubber baby buggy bumper, you mean left speaker, then yes, I agree. Reinstall the hard drive before the left speaker.
    jerrid_foiles -
    Kudo to @jerrid_foiles! I was going crazy trying to attach the SATA cable until I took the two screws out of the left speaker and slid the top end of it aside by about 3/4 inch. Make the whole process SO MUCH easier!!
    jiclark - 返信
    We solved this by removing the hard drive tray screw, then inserting the cable into the SATA hard drive. Then hold the hard drive a bit out of the way to insert the 7.3mm hard drive tray screw.
    Marjie - 返信
    Agree with this method, found it an impossible task to reconnect the SATA connector until removed the tray screw, then it was relatively easy to reconnect and then replace the tray screw.
    daveedwards -
    Also agree with this method!
    jmorphett5 -
  43. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 43、 1の画像 1
    • ハードドライブのアセンブリをiMacから取り出します。
    When reassembling, I found it easier to loosen the HD tray screw from Step 48 and pull the tray outwards from the left side in order to plug the SATA cable in more easily.
    Cool_Breeze - 返信
    Thanks! I, too, had a hard time reconnecting the SATA cable.
    boboswell -
    I found this helpful too!
    Anwar -
    And DON’T do what I did, which is to remove the left speaker - which can easily lead to breaking the cable between the power on button and the power supply. The cable is routed through a hidden slot at the very bottom of the left speaker
    bsmith1 - 返信
    I did loosen the speaker so I could get a tool behind the SATA cable to push it on to the SSD drive. Otherwise hard to align cable.
    Noah Ralston - 返信
    I found the easiest way to connect the SATA cable was to not screw the plastic hard drive tray down until you plug the drive in. That way you can easily push the connector in and due to the cable you’ve got some wiggle room. You can position the tray then just lift one end of the drive up and secure the screw. Then just push the drive down.
    Chris Caldwell - 返信
    This was the step that I had the most trouble with. I’m used to replacing a hard drive in a MacBook Pro, where the “plug” that you plug the drive into is a rigid thing that you can firmly press the hard drive into.
    With the iMac, the plug is situated on the end of a non-rigid cord, so the plug moves back when you try to snap a drive into it. Also, those two rubber gasket things that you adhere to the side of the drive really make it difficult to maneuver the now-overly-chubby drive towards the plug.
    After must frustration/concern, what I ended up doing was temporarily removing the rubber gasket things, using the “spudger” as kind of a lever behind the “plug on a cord” so that it didn’t move as much, and then pushed the gasket-less SSD into the plug.
    Once I got it connected, I put the rubber gaskets back on the sides of the SSD and kind of coaxed it down into place, using the pointy end of the spudger to get the chubby corner pieces to “sit” correctly in the rigid plastic tray that the SSD kind of rests in.
    Jack OnFlickr - 返信
    From another comment elsewhere on this repair, I *highly* recommend removing the two screws holding the left speaker in place, then sliding it just a tad out of the way to be able to easily attach the SATA cable. You don’t have to move it much to make the whole process so much easier!
    jiclark - 返信
  44. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換, ハードドライブトレイ: 手順 44、 1の画像 1
    • リアエンクロージャーにハードドライブトレイを固定している7.3 mm T8トルクスネジを外します。
    it`s a t10 screw..! ;)
    happymac venezuela - 返信
    I found it easier to connect SATA cable before fixing tray.
    Mārtiņš Jansons - 返信
  45. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 45、 1の画像 1
    • ハードドライブトレイを取り出します。
    I am following these procedures for the following: iMac Retina 4K - 21.5" - 3GHz Quad Core - Radeon Pro 555 2GB - 4GB/4GB (8GB total - 2 slots) 2400MHz DDR4 SO-DIMM - Mid 2017 - Model: MNDY2LL/A - iMac18,2 - A1418 - 3069. In my case, the SATA cable is clipped into the bottom of the hard drive tray. Pull the hard drive tray up slightly and angle to reveal clips. SATA cable pops out from the side of each clip.
    iannai29 - 返信
    Better yet, after reading Step 49 - no need to remove SATA cable from the bottom of the hard drive tray.
    iannai29 - 返信
  46. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換, ロジックボードアセンブリ: 手順 46、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換, ロジックボードアセンブリ: 手順 46、 2の画像 2
    • ロジックボードのソケットから、左側スピーカーケーブルを慎重に引き抜きます。
  47. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 47、 1の画像 1
    • 左側スピーカーケーブルを背面エンクロージャーの裏にある固定クリップからまっすぐ引き上げて、配線を外します。
  48. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 48、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 48、 2の画像 2
    • 前の手順を繰り返して、SATAと電源ケーブルを固定クリップからまっすぐに引き上げて接続を外します。
  49. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 49、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 49、 2の画像 2
    • SARA電源とデーターケーブルに、左側スピーカーコネクタを装着しているテープの一部分を剥がします。
  50. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 50、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 50、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 50、 3の画像 3
    • Face Timeカメラケーブルコネクタ上のメタル製固定ブラケットを裏返します。
    • Face Timeカメラケーブルをロジックボードのソケットからまっすぐ引き抜きます。
    • これは破損しやすいデリケートなコネクタです。作業は慎重に行なってください。
  51. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 51、 1の画像 1
    • AirPort/Bluetoothカードに4本のアンテナコネクタを接続している、4.0mm T5トルクスネジを2本外します。
  52. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 52、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 52、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 52、 3の画像 3
    • AirPort/Bluetoothカード上のソケットから4つのアンテナコネクタをこじ開けて、接続を外します。
  53. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 53、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 53、 2の画像 2
    • 右側スピーカーケーブルのコネクタを、ロジックボード上のソケットからまっすぐ引き抜きます。
  54. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 54、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 54、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 54、 3の画像 3
    • スパッジャーの平面側先端を使って、ロジックボード上のソケットからヘッドホンジャックのケーブルコネクタをこじ開けます。
    • わずかにケーブルを右側に押し寄せます。
  55. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 55、 1の画像 1
    • 排気ダクトを覆っているテープを剥がします。
  56. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 56、 1の画像 1
    • 背面エンクロージャーに排気ダクトを固定しているT8トルクスネジを外します。
    • 6.2mmネジー2本
    • 4.7mmネジー2本
  57. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 57、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 57、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 57、 3の画像 3
    • スパッジャーの先端を使って、マイクロフォンリボンケーブルのZIFソケット上にある固定フラップを引き抜いて外します。
    • ヒンジのついた固定フラップ上をこじ開けてください。ソケット自体には触らないでください。
    • マイクロフォンリボンケーブルを、ソケットから慎重にまっすぐ引き抜きます。
  58. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 58、 1の画像 1
    • 背面エンクロージャーにロジックボードを固定している、7.3mm T8トルクスネジを4本外します。
  59. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 59、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 59、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 59、 3の画像 3
    • ロジックボードを背面エンクロージャーから離すように上部を傾けます。
    • ロジックボードを傾けたら、右側のスピーカーコネクタを右側に引っ張り、ボードから外します。
    • ロジックボードをまっすぐ持ち上げて、iMacから取り出します。
    • ボードに背面エンクロージャーのネジポストを引っ掛けないよう、ご注意ください。
    When repairing, I accidentally broke a small piece of what it seems to be a resistor. Mac still works fine and diagnostics reports no errors. Be careful when removing the mother carefully so it doesn’t hit the aluminium cover.
    Andres Urena - 返信
  60. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 60、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 60、 2の画像 2
    • iMacを再組み立てする際は、外側のI/Oポートが正しく位置が揃っているか確認してください。ロジックボードは全てのネジを閉めても傾いた状態で装着します。
    • ロジックボードが正しい位置に装着するように、USBフラッシュドライバと/もしくはイーサーネットケーブルを使い、ネジを締めてください。
  61. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換, SATAデータ/パワーケーブル: 手順 61、 3の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換, SATAデータ/パワーケーブル: 手順 61、 3の画像 2 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換, SATAデータ/パワーケーブル: 手順 61、 3の画像 3
    • SATAデータコネクタには、クリップが付いており、これを押して外します。
    • 指でクリップを押さえながら、ロジックボードのソケットからSATAデータコネクタを持ち上げて、接続を外します。
  62. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 62、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 62、 2の画像 2
    • ハードドライブのパワーコネクタを摘んで、ロジックボード上のソケットからゆっくりと引き抜きます。
  63. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換, ヒートシンクアセンブリ: 手順 63、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換, ヒートシンクアセンブリ: 手順 63、 2の画像 2
    • ヒートシンクを固定しているネジを隠しているボイドシールを剥がします。
    • ロジックボードの裏側からヒートシンクを固定している、T10ネジを4本外します。
    • 再組み立ての際は、これらのネジを一度に1回転ずつ、十字パターンで交互に締めていきます。 これによりCPUの表面全体のクランプ圧力を均等に上昇させることができます。 ネジがきちんと締まり、スプリングプレート全体がロジックボードに対して水平になるまで、徐々にネジを締めていきます。
  64. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 64、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 64、 2の画像 2
    • ロジックボードからヒートシンク固定スプリングとブラケットを持ち上げます。
  65. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 65、 1の画像 1
    • GPU上のヒートシンクを固定している、T8脱落防止ネジを3本完全に緩めます。
    • ロジックボードにヒートパイプを固定している、5.4mm T8ネジを2本外します。
  66. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 66、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 66、 2の画像 2
    • CPUを持ち上げた際に、ヒートシンクの下側で引っかかっている可能性が高いことに注意してください。 傷つけないよう、作業は慎重に行なってください。
    • ヒートシンクアセンブリを、ロジックボードから持ち上げて取り出します。
  67. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換, CPU: 手順 67、 1の画像 1
    • ヒートシンクを裏返して、スパッジャーを使ってCPUを取り出します。落とさないようにご注意ください。
    • 放熱グリスの厚いレイヤーがCPUを固定しています。
  68. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 68、 1の画像 1
    • CPUをヒートシンクから取り出します。
  69. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 69、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 69、 2の画像 2
    • 糸くずの出ないマジックワイプなど(もしくはコーヒーフィルター)にイソプロピルアルコールもしくはArctiCleanサーマル素材リムーバーを含ませて、CPUとヒートシンクのGPUアーム両方から放熱グリスの残骸を綺麗に拭き取ります。
    • ヒートシンクの表面が完全に綺麗になったら、未使用のマジックワイプもしくはコーヒーフィルターにイソプロピルアルコールあるいはArctiCleanサーマル素材リムーバーを含ませて、油脂などを綺麗に拭き取ります。コッパーのヒートシンク表面をクリーニングしてください。
    • コッパーの表面を素手で触らないでください。埃やゴミが表面に付着してしまいます。指紋でさえ熱伝導の大きな障害となります。アクシデントで触れてしまった場合は、表面を綺麗に拭き取ってください。
    • ヒートシンクを完全に乾かせてから、次の作業に移ります。
  70. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 70、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 70、 2の画像 2
    • スパッジャーを使ってGPUから余分な放熱グリスの残留を慎重に拭き取ります。
    • 前の作業と同じく、糸くずの出ないマジックワイプやコーヒーフィルターにイソプロピルアルコールを含ませて、GPU表面を綺麗に拭き取ります。
    • GPU周辺の4つのVRAMチップからも放熱グリスを拭き取ります。
  71. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 71、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 71、 2の画像 2
    • GPU周辺の4つのVRAモジュールにサーマルパッドを装着します。
    • あるいは、K5-PROのような厚めの放熱グリスを塗布することもできます。
    • ピンセットでサーマルパッドの上部からライナーを剥がします。
    Gibt es dafür passende Leitpads ?
    Paul - 返信
  72. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 72、 2の画像 1 iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 72、 2の画像 2
    • インストール前に、CPUの装着方向を確認してください。
    • CPU端にある小さな切り欠きはソケットのサイドにある凹みと合わさります。
    • 新しいCPUをマザーボード上のソケットに揃えて慎重に装着します。
    Is it possible for the 21.5, 4K model to support/handle the i7-7700k processor?
    Danilo Jiménez - 返信
  73. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 73、 1の画像 1
  74. iMac Intel 21.5インチ Retina 4K Display (2017) CPUの交換: 手順 74、 1の画像 1
    • GPUに少量の放熱グリスを塗布します。
    • ヒートシンクに放熱グリスを塗布する必要はありません。Arctic Silverはヒートシンクの表面に”ティントを付ける”ことを推奨していますが。 この方法と一般的な放熱グリスのアプリケーション方法については、Arctic Silverウェブサイト情報を参照してください。
    • これでCPUとGPU上にヒートシンクをインストールできます。
終わりに
デバイスを再組立する際は、これらのインストラクションを逆の順番に従って作業を進めてください。
19 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
作成者
5人の作成者と共同で作成されました。
Adam O'Camb
メンバー登録日: 04/11/15
196,116 ポイント
416のガイドは作成済み
36 件のコメント
Can I upgrade to i7 7700K on iMac 2017 21.5inch ?
Imperius lu - 返信
looking at the compare on intel’s website:
https://ark.intel.com/compare/97128,9712...
the 7700k being a 130w vs any Apple installed CPU being 65W, I’d think the the likelihood to overheat or draw too much power would be high but I don’t have enough experience to know for certain.
Benjamin -
Can I upgrade to Intel Core i7 8700K?? It’s LGA 1151… so? iMac 2017, 21,5inch
Mikkser - 返信
Hey Mikkser, 8-series (Coffee Lake) CPUs require the Z370 chipset, which to my knowledge isn’t on the 2017 iMac logic boards. The socket is the same as the last generation so you’d be able to plug an 8700K in, but it wouldn’t work.
Adam O'Camb -
Intel Core i7-8700K Desktop Processor 6 Cores up to 4.7GHz Turbo Unlocked LGA1151 300 Series 95W BX80684i78700K would that work with it
johnm - 返信
8th Gen isn’t compatible with chipset. see previous comments.
Benjamin -
The Intel Core i7 8700K is an eighth generation Intel CPU.  8th gen Intel CPU’s aren’t compatible with Socket LGA 1151 revision 1 which is what iMac’s use.  6th and 7th gen Intel Core i3/i5/i7 are compatible, but again not 8th gen.
robert_perdue -
What are the maximum specs for cpu, gpu and ram available for this device_ thank you
what I mean is: can install a i9? which is the most powerful gpu the computer will hold? is it possible to install ddr4 ram and still dont create a bottleneck in the motherboard? thanks
ivan diaz - 返信
There are no i9 CPUs on a FCLGA1151 Socket which this iMac model uses.
Benjamin -
The Intel Core i9 uses socket LGA2066 and not 1151 revision 1.   Also the GPU is not replaceable in the iMac as replacement GPU’s aren’t available and even if they were I don’t think you can remove the GPU anyway.
robert_perdue -
hi, can i use the Intel Core i7-7700K 4.2Ghz my iMac 21.5 4k 2017 instead of the 3.6ghz version? thanks a lot.
vicky - 返信
Hey Vicky, you CANNOT use the i7-7700k for this model as the logic board doesn’t recongize it. I tried it myself and found out the the non k version (i7-7700) does work with it. It would be nice if someone could update this guide for future people trying to upgrade the cpu!
William Randolph -
@willran Thanks for this. I had incorrectly stated that we tested the unlocked version—we didn’t. Like you, we used the vanilla i7-7700 and it’s still working great. I’ve removed the 7700k from the parts list. Good catch!
Jeff Suovanen -
Purchased the kit, maxed to 32GB and i7-7700 (non k version), this thing SCREAMS now with the upgrade! (I do code and a lot of Sketch work…) The whole thing took me 3 hours.. the most time was spent on removing the *!&*^#% adhesive from the screen back panel and the frame. THANK YOU for the guide, the instructions were 100% correct, cheers
Philippe Léger - 返信
Just upgraded from i5-7500 to i7-7700 (also did SSD and RAM). Anyone experiences higher temps or random temp spikes/increase in fan activity?
jesse.johnston - 返信
I have 7700K and I have not seen any issues.
ua2599 -
did you add enough thermal paste? Also @ua2599 do you really have the 7700k working properly on this model imac? Can you tell me about it?
Frank Mendoza -
@frankomendozer yes it working for me and been working for a while now. i had to troubleshoot multiple times to get it to work. my Thunderbolt was not working after the install so I had to do installation of the OS multiple times. I changed my HDD to SSD. I had to break the fusion dive and remake the fusion drive and reinstall. It was time consuming.
ua2599 -
I have had no issues with 7700K @4.2 GHz . No heat up issues as its a 91W TDP. Been using to edit in FCP . @frankdoof
ua2599 - 返信
iMac Intel 21.5 "Retina 4K Display (2017) Replaced the processor with i7 7700 computer like booting, but no image, the screen does not light up. If you put the i5 processor back, it 's OK. What's the reason?
sherlok74 - 返信
I have the same issue upgrading to a i7-7700, got the boot chime but the monitor is blank, it will eventually boot into MacOS (the reason I know this is because I can hit the volume level keys and I can hear the feedback when the volume is changed.) but again, no display. Yes, I double-checked the screen connectors to ensure they are firmly installed. Tried nvram & SMC reset. still no display.
Animefuntv -
UPDATE! So I took a chance and removed the mainboard from the iMac again, removed the coin battery from the mainboard, took a screwdriver, and touched the positive and negative of the battery holder for several seconds (in theory this should hard reset the smc/pram). reinstalled everything and BAM! I got my screen back! and it booted right into MacOS! Checked the system info and it shows an i7 CPU installed!
Animefuntv -
Процессор Intel Core i7-7700 для настольных ПК 4 ядра с частотой до 4,2 ГГц LGA 1151 серии 100/200, 65 Вт
sherlok74 - 返信
So this is the processor to buy right guys http://www.tigerdirect.com/applications/... ???????????????
Darrell - 返信
Hello I have done the manipulation of replacing the i5 by i7 7700 k or not k and it does not work I only had a black screen...I had no luck
lionel.porrelli - 返信
Hello, I have installed 7700K and its been working for past few years. I had issues as well but my issue was the USB-C ports were not working. I tested different cables, different devices but nothing would connect but mac would start and run smoothly. I had to reinstall OS multiple times and i think that made the ports work. No issues ever since. Goodluck
ua2599 -
I am thinking it will work but I will wait for others to respond.
Cameron E -
yes it will work. I have 7700K working.
ua2599 -
@ua2599 Awesome thank you! it not being a 65w TDP wont matter? i think i read earlier that you had issues. Would i run into these USB issues with the K vs the non K version?
also, whats the drawbacks or benefits of running a 65w TDP vs 95w TDP
Cameron E - 返信
I have not seen any issues with 95w TDP. You gain little speed but 95w will produce more heat so if we keep it in cool environment then you should be okya. Mine is working smoothly, initially i had issues with USB but after redoing it multiple times ( as in putting it back to original setting and then doing the mod) it got fixed…. Not sure how but it was fixed and its been working ever since. Good luck…
ua2599 -
Will it still work if I have an iMac 21.5 2017 but non 4k?
Aug Litv - 返信
Can the power supply cable going from the psu to the logic board
https://guide-images.cdn.ifixit.com/igi/...
be replaced (bought separately)?
On my iMac EMC 3069 it is different (no connector/adapter as shown on the image) and it is cut (damaged). The leads coming through insulation.
Do they have problems/troubles with this cable when manufacturing/assembling?
AW_itfixi - 返信
Hallo an Alle, ich habe da ein Problem. Mir ist das Flexkabel am Mikrofon durchgebrochen. Nun ist es nicht mehr zu gebrauchen. Habe schon drei Tage danach im Internet gesucht, aber ich finde nichts. Hat jemand von Euch eine Bezugsadresse oder noch ein herumliegen? Besten Dank im Voraus und viele Grüße
Dusch Hahn - 返信
Will a Intel Core i7-8700 Desktop Processor 6 Cores up to 4.6 GHz LGA 1151 300 Series 65W work in a 2017 iMac 4k currently 8gb ram, 3.4ghz quad core.
Mark - 返信
コメントを追加
統計データ:
過去 24時間: 20
過去 7 日: 120
過去 30 日: 512
今までの合計 33,156
