この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Remove your display panel to gain access to the hard drive, optical drive, and power supply.
必要な工具と部品
Lay your iMac front side down on a table with the lower edge facing yourself.
Loosen the single Phillips screw in the center of the access door.
Remove the access door from your iMac.
この手順で使用する道具:Heavy-Duty Suction Cups (Pair)$14.95
Stick two suction cups to opposing corners of the glass panel.
Remove the following 12 screws securing the front bezel to the rear case:
Eight 13 mm T8 Torx.
Four 25 mm T8 Torx.
Gently lift the front bezel from its top edge off the rear case.
Once the top edge of the front bezel has cleared the rear case, rotate the front bezel toward the stand and lift it off the rear case.
Rotate the front bezel away from the rest of the device and lay it above the top edge of the iMac.
Pull the LCD temperature sensor connector straight up off its socket on the logic board.
(located at the top of the logic board on the 24")
8 の人々がこのガイドを完成させました。
