このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
Place your hands at the top corners of the bezel (to the side) and lift the bezel 2-3cm from the body by working from the top. After this you can also disengage the bottom of the bezel (the memory modules will prevent the bottom of the bezel to detach first). When reassembling, start with the bottom of the bezel.
To fully detach the bezel: disconnect the microphone cable connector, removing tape as necessary.
To keep it attached, leave the microphone cable attached to the logic board, and place the bezel 'above' the chassis, with the microphone cable forming a hinge.
この手順は未翻訳です。 翻訳を手伝う。
be sure to tuck the microphone cable and connector into the void next to the camera board.
Gently guide the microphone connector and cables through the ±1in long slot at the right of the iSight camera. Once the bezel is properly assembled, gently push the microphone connector and cable into the bezel through that slot.
26 の人々がこのガイドを完成させました。
2 件のコメント
Thanks for that, going to try this tomorrow, hopefully will resolve my rebooting issue.
Narmi Tech - 返信
GENIUS!!! I suffered 2 and a half years not wanting to toss a DEAD iMac and that was wrong was a $3 CR2032 f’ing battery!! THANK YOU!
