はじめに
Like brain surgery? Use this guide to replace your logic board.
Loosen the single Phillips screw in the center of the access door.
Remove the access door from your iMac.
Stick two suction cups to opposing corners of the glass panel.
Remove the following 12 screws securing the front bezel to the rear case:
Eight 13 mm T8 Torx.
Four 25 mm T8 Torx.
Place your hands at the top corners of the bezel (to the side) and lift the bezel 2-3cm from the body by working from the top. After this you can also disengage the bottom of the bezel (the memory modules will prevent the bottom of the bezel to detach first). When reassembling, start with the bottom of the bezel.
To fully detach the bezel: disconnect the microphone cable connector, removing tape as necessary.
To keep it attached, leave the microphone cable attached to the logic board, and place the bezel 'above' the chassis, with the microphone cable forming a hinge.
be sure to tuck the microphone cable and connector into the void next to the camera board.
Gently guide the microphone connector and cables through the ±1in long slot at the right of the iSight camera. Once the bezel is properly assembled, gently push the microphone connector and cable into the bezel through that slot.
Pull the LCD temperature sensor connector straight up out of its socket on the logic board.
If necessary, de-route the LCD temperature sensor cable from behind the logic board.
With the display panel still lifted, disconnect the four inverter cables.
If you are replacing a hard drive and have an extra set of hands, it is possible to reach in and remove the drive without disconnecting anything but the LCD temp and display connector in the previous step with the LCD in its propped position.
Disconnect the left speaker cable connector from the audio board by pulling it straight away from its socket.
Disconnect the power button and CPU fan by lifting their connectors straight up off the logic board.
Disconnect the SATA data cable from the logic board by carefully pulling it straight away from its socket.
Remove the following 13 screws securing the logic board to the rear case:
Six 7.2 mm coarse-thread T10 Torx.
Two 6.8 mm T8 Torx. When reinstalling these two screws, don't overtighten them, as the plastic tabs they hold down are thin and brittle, and can crack.
Three 7 mm fine-thread T10 Torx.
Two 24 mm T10 Torx.
40 の人々がこのガイドを完成させました。
7 件のコメント
Superb instructions. just replaced my iMac 2007 with another motherboard as I had a faulty ram slot and put in a new SSD hard drive. Would have struggled without this step by step guide.
john riley - 返信
Thanks. I was able to successfully replace the logic board following these instructions. I'm not sure I would have been able to do it on my own.
How is named the block right above the ram slots? This thing covered with the bright aluminium « mini-Manhattan » :) (or « porcupine »)?
I thought it was the CPU itself but if I read correctly, CPU is under the 45° structure. Right? Thank you.
I’m sorry for the late answer, but I believe the chip under that heat sink is the North Bridge. It controls data transfer between the CPU, RAM, and graphics.
What is the thing above the ram slots? That thing with the bright aluminium « porcupine » on top of it ;) thank you
