メインコンテンツにスキップ
iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement
必要条件のみ
この修理ガイドは、他のガイドの前提条件として使用されます。それ自体は不完全で、単独で使用されることはありません。
  1. iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement, Hard Drive: 手順 1、 1の画像 1
    • If necessary, remove the pieces of tape securing the hard drive/optical drive thermal sensor cables to your iMac.
  2. iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement: 手順 2、 1の画像 1
    • Disconnect the hard drive thermal sensor by pulling its connector toward the top of your iMac.
    • When removing this connector, it is helpful use your thumbnails to push the ears on either side of the connector toward the top of your iMac.
  3. iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement: 手順 3、 2の画像 1 iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement: 手順 3、 2の画像 2
    • Pressing the top of the hard drive bracket down to release it from the rear case requires a substantial amount of force. We recommend laying your iMac stand-side down on a table to avoid knocking it over.
    • Press the hard drive bracket down toward the bottom edge of your iMac to free it from the rear case, then rotate the top of the drive toward yourself.
  4. iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement: 手順 4、 2の画像 1 iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement: 手順 4、 2の画像 2
    • Rotate the hard drive toward yourself, then lift it up off its mounting pins.
    • The hard drive is still connected via the SATA cables.
    • When reinstalling your hard drive, be careful not to push the rubber grommets through the openings in the chassis with the lower hard drive pins as retrieving them may require logic board removal.
  5. iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement: 手順 5、 1の画像 1
    • Insert the flat end of a spudger between the SATA power cable connector and the edge of the hard drive.
    • Twist the spudger to separate the connector from the hard drive.
  6. iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement: 手順 6、 1の画像 1
    • Pull the SATA power connector away from the hard drive.
  7. iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement: 手順 7、 1の画像 1
    • Disconnect the SATA data cable by pulling its connector away from the hard drive.
終わりに
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Walter Galan
694,825 ポイント
1,203のガイドは作成済み
コメント 1 件
Walter, I was working on a mid-2007 IMac (2133) and found your instructions helpful but not always complete or right. I have added some comments in some of the steps to clarify.
Pablo Guerrero - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 13
今までの合計 2,890
