メインコンテンツにスキップ
iMac Intel 20" EMC 2133 and 2210 AirPort Extreme Replacement
必要な工具と部品
  1. iMac Intel 20" EMC 2133 and 2210 AirPort Extreme Replacement, Access Door: 手順 1、 1の画像 1
    • Loosen the single Phillips screw in the center of the access door.
    • This screw is captive in the access door.
    • Remove the access door from your iMac.
  2. iMac Intel 20" EMC 2133 and 2210 AirPort Extreme Replacement, Glass Panel: 手順 2、 2の画像 1 iMac Intel 20" EMC 2133 and 2210 AirPort Extreme Replacement, Glass Panel: 手順 2、 2の画像 2
    この手順で使用する道具:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    購入する
    • The glass panel is fixed onto the front bezel with fourteen magnets around its perimeter.
    • Stick two suction cups to opposing corners of the glass panel.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent such as Windex.
  3. iMac Intel 20" EMC 2133 and 2210 AirPort Extreme Replacement: 手順 3、 1の画像 1
    • Gently pull the glass panel straight up off the iMac.
    • The glass panel has several positioning pins around its perimeter. To avoid shearing these pins off the glass panel, be sure to only pull straight up during removal.
    • Be meticulous about cleaning the LCD and the inside face of the glass panel before reinstallation, as any fingerprints or dust trapped inside will be annoyingly visible when the display is on. Placing the glass flat, inside face down, on a fresh aluminum-foil surface is a good way to keep it clean.
  4. iMac Intel 20" EMC 2133 and 2210 AirPort Extreme Replacement, Front Bezel: 手順 4、 1の画像 1
    • Remove the following 12 screws securing the front bezel to the rear case:
    • Eight 13 mm T8 Torx.
    • Four 25 mm T8 Torx.
  5. iMac Intel 20" EMC 2133 and 2210 AirPort Extreme Replacement: 手順 5、 1の画像 1
    • Place your hands at the top corners of the bezel (to the side) and lift the bezel 2-3cm from the body by working from the top. After this you can also disengage the bottom of the bezel (the memory modules will prevent the bottom of the bezel to detach first). When reassembling, start with the bottom of the bezel.
    • The top of the bezel hosts a microphone attached to the logic board. Gently lift the bezel to not damage the microphone wiring or connector by accidentally pulling the cable.
    • At this point, you can either detach the microphone cable and remove the bezel, or keep the microphone cable attached and rest the bezel on your work surface or the chassis of the Mac.
    • To fully detach the bezel: disconnect the microphone cable connector, removing tape as necessary.
    • To keep it attached, leave the microphone cable attached to the logic board, and place the bezel 'above' the chassis, with the microphone cable forming a hinge.
    • If you keep the microphone attached to the chassis, make sure you don't accidentally damage the microphone or logic board by bumping into the loose bezel.
  6. iMac Intel 20" EMC 2133 and 2210 AirPort Extreme Replacement: 手順 6、 2の画像 1 iMac Intel 20" EMC 2133 and 2210 AirPort Extreme Replacement: 手順 6、 2の画像 2
    • When reassembling the bezel:
    • be sure to tuck the microphone cable and connector into the void next to the camera board.
    • Gently guide the microphone connector and cables through the ±1in long slot at the right of the iSight camera. Once the bezel is properly assembled, gently push the microphone connector and cable into the bezel through that slot.
  7. iMac Intel 20" EMC 2133 and 2210 AirPort Extreme Replacement, AirPort Extreme: 手順 7、 2の画像 1 iMac Intel 20" EMC 2133 and 2210 AirPort Extreme Replacement, AirPort Extreme: 手順 7、 2の画像 2
    • Use the flat end of a spudger to pry both antenna connectors up off the AirPort Extreme card.
  8. iMac Intel 20" EMC 2133 and 2210 AirPort Extreme Replacement: 手順 8、 1の画像 1
    • Remove the single 5.4 mm T6 Torx screw securing the AirPort Extreme card to the logic board.
    • The free end of the AirPort card should pop up slightly.
  9. iMac Intel 20" EMC 2133 and 2210 AirPort Extreme Replacement: 手順 9、 1の画像 1
    • The free end of the AirPort Extreme card should lift slightly.
    • Pull the AirPort Extreme card straight away from its socket.
終わりに
13 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Walter Galan
694,877 ポイント
1,203のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 40
今までの合計 20,300
