メインコンテンツにスキップ
iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement
必要な工具と部品
  1. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement, Access Door: 手順 1、 2の画像 1 iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement, Access Door: 手順 1、 2の画像 2
    • Loosen the two Phillips screws securing the access door to your iMac.
    • Both screws remain captive within the access door.
    • Remove the access door.
    • Before beginning the repair, unplug the computer and press and hold the power switch for 20-30 seconds, to discharge internal capacitors.
  2. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement, Front Bezel: 手順 2、 1の画像 1
    • Remove the following screws along the lower edge of your iMac:
    • Three 6 mm T8 Torx screws
    • One 8 mm T8 Torx screw (Right side of the RAM slot on 2105)
  3. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 3、 3の画像 1 iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 3、 3の画像 2 iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 3、 3の画像 3
    この手順で使用する道具:
    Plastic Cards
    $2.99
    購入する
    • Re-orient your iMac so it sits upright on the stand.
    • Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
    • Push the card toward the top of the iMac to release the front bezel latch.
    • Pull the front bezel away from the rear case.
    • Repeat this process for the other side of the front bezel.
    • It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches. Or use two cards for the additional thickness.
    • If the bezel refuses to release, try lifting the lower edge of the front bezel slightly away from the rear case (detailed in the next few steps) and repeat the latch release process.
  4. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 4、 2の画像 1 iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 4、 2の画像 2
    • Lay your iMac stand-side down on a flat surface.
    • To lift the front bezel off the iMac, simultaneously:
    • Use your thumbs to press in the RAM arms and hold the iMac down.
    • Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
    • Pull the front bezel up with your index fingers.
    • Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
  5. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 5、 2の画像 1 iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 5、 2の画像 2
    • Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge.
  6. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 6、 1の画像 1
    • If necessary, remove the strip of tape covering the microphone cable connector.
    • The microphone connector is located near the inside of top edge of your iMac.
  7. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 7、 3の画像 1 iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 7、 3の画像 2 iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 7、 3の画像 3
    • Disconnect the microphone cable.
    • Disconnect the camera cable by pulling its connector away from the socket on the camera board.
    • The camera cable connector and socket are delicate and easily bent. Remove with caution.
  8. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement, Lower EMI Shield: 手順 8、 1の画像 1
    • Peel up the lower EMI shield from the rear case.
    • It is only necessary to peel the shield up from three sides. Leave it attached to the display.
    • If you happen to rip the EMI shield, use a piece of foil tape to cover the tear.
  9. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 9、 1の画像 1
    • Tape the EMI shield to the face of the display to keep it out of the way.
  10. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement, Display: 手順 10、 2の画像 1 iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement, Display: 手順 10、 2の画像 2
    • Remove the two 5 mm T6 Torx screws securing the display data cable connector to the logic board.
    • Pull the display data cable connector up off the logic board by its black pull tab.
  11. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 11、 1の画像 1
    • Peel back the EMI tape from the two vertical edges of the display.
    • During reassembly, it is helpful to use several small strips of tape to hold the EMI shielding along the left and right edges of the display footprint out of the way before lowering the display into the rear case of your iMac.
  12. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 12、 2の画像 1 iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 12、 2の画像 2
    • Allow the lower EMI shield to hang down from the display.
    • Remove the four 7.5 mm T10 Torx screws securing the display to the rear case.
    • The screws are recessed, so a thin magnetic screwdriver aids in removal. Most bit drivers are too short to reach these screws.
  13. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 13、 1の画像 1
    • Lift the lower edge of the display and rotate it toward the top edge of your iMac.
    • Do not lift it too much, as the inverter cables are still attached.
  14. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 14、 2の画像 1 iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 14、 2の画像 2
    • Disconnect both inverter cables from the inverter board.
    • These connectors are seated very tightly in their sockets. It is helpful to use your fingernails or the tip of a spudger to push the ears on either side of the connectors to dislodge them from their sockets. A small pair of hemostats helps a lot.
  15. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 15、 1の画像 1
    • Disconnect the two inverter cables at the top edge of the inverter using the method explained in the previous step.
  16. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 16、 1の画像 1
    • Rotate the display until it is nearly perpendicular to the rear case and lift it up to peel it off the EMI shield stuck to its top edge.
  17. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement, Speakers: 手順 17、 2の画像 1 iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement, Speakers: 手順 17、 2の画像 2
    • Remove the single T10 Torx screw securing the left speaker to the rear case.
    • Pull the left speaker out of the rear case.
    • The screw for the left speaker is longer than the screw for the right speaker.
  18. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 18、 2の画像 1 iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 18、 2の画像 2
    • Use the flat end of a spudger to pry both antenna connectors up off the AirPort Extreme card.
    • Some models may have only one AirPort antenna wire.
  19. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 19、 2の画像 1 iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 19、 2の画像 2
    この手順で使用する道具:
    Metal Spudger
    $2.99
    購入する
    • Use a metal spudger to disconnect the SATA data cable up off the logic board.
    • The SATA connector on most iMacs tends to stick in its socket on the logic board. If you are having trouble disconnecting the SATA cable, insert a metal spudger or any other thin tool into the gap between the SATA connector and its socket and twist the spudger's shaft to safely separate the two pieces.
  20. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 20、 1の画像 1
    • Pull the IR board cable connector away from its socket on the IR board.
    • Pull the connector parallel to the face of the logic board.
  21. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 21、 1の画像 1
    • De-route the speaker cables from beneath the IR Board and heatsink assembly.
  22. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 22、 2の画像 1 iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 22、 2の画像 2
    • Remove the single T10 Torx screw securing the right speaker to the logic board.
    • Lift the right speaker out of the rear case and move it out of the way.
    • Both speakers are still attached to the logic board by the speaker cable.
  23. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 23、 1の画像 1
    • Disconnect the speaker cable connector by lifting it straight up off its socket on the logic board.
  24. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement, Logic Board: 手順 24、 2の画像 1 iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement, Logic Board: 手順 24、 2の画像 2
    • Disconnect the HDD fan and power button from the logic board by pulling their connectors straight up off the sockets on the logic board.
  25. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 25、 1の画像 1
    • If necessary, remove the pieces of tape holding the SATA data cable to the logic board.
    • Move the SATA data cable away from the face of the logic board.
  26. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 26、 2の画像 1 iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 26、 2の画像 2
    • Disconnect the DC-In cable by simultaneously depressing both locking arms and pulling its connector away from the socket on the logic board toward the top of your iMac.
    • After both locking arms pass their retaining tabs, it is helpful to push the arms toward the top edge of your iMac while wiggling the connector.
  27. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 27、 1の画像 1
    • Pull the ambient light sensor cable connector up off the logic board.
  28. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 28、 1の画像 1
    • Use the flat end of a spudger to pry the Bluetooth antenna cable connector up off the Bluetooth board.
  29. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 29、 1の画像 1
    • Carefully de-route the IR board cable out from under the IR board and move it out of the way of the logic board.
  30. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 30、 2の画像 1 iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 30、 2の画像 2
    • Disconnect the following connectors from the logic board:
    • Camera/IR board cable.
    • Optical drive fan.
    • When removing the optical drive fan connector, it is helpful to use a spudger or your fingernails to push the ears on either side of the connector toward the top edge of the iMac.
    • To aid in removing the camera/IR board connector, it is helpful to use one hand to pinch the cables against a spudger and pull up toward the top edge of the iMac while pulling up gently on the cables with your other hand.
  31. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 31、 1の画像 1
    • Disconnect the optical drive thermal sensor cable from the logic board by pulling its connector away from the socket on the logic board.
  32. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 32、 1の画像 1
    • Remove the two T6 Torx screws securing the optical drive ribbon cable connector to the logic board.
  33. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 33、 1の画像 1
    • Use the flat end of a spudger to pry the optical drive ribbon cable connector up off the logic board.
    • The connector is most easily removed when prying from the top or bottom of the connector.
    • Bend the optical drive ribbon cable back away from the logic board.
    • Be very careful when moving the optical drive ribbon cable as it is delicate and easily ripped.
  34. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 34、 1の画像 1
    • Hard drive thermal sensor cable.
    • CPU fan cable.
    • When removing these connectors, it is helpful to push the ears on either side of the connector with your fingernails or the tip of a spudger toward the top edge of the iMac.
  35. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 35、 1の画像 1
    • Remove the two T6 Torx screws securing the top of the heat sink framework to the chassis.
  36. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 36、 1の画像 1
    • Remove the following seven screws securing the logic board to the rear case:
    • Three coarse-thread T10 Torx.
    • Three fine-thread T10 Torx.
    • One long coarse-thread T10 Torx.
  37. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 37、 1の画像 1
    • Carefully rotate the top edge of the logic board out of the rear case and lift the board up out of the iMac, minding the RAM arms and any cables that may get caught.
    • Be especially careful with the hard drive thermal sensor cable that is routed underneath the heat sink framework.
    • Only handle the logic board by its edges.
  38. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement, Power Supply: 手順 38、 1の画像 1
    • The next few steps bring your hands close to the exposed face of the power supply. Do not touch the face of the power supply to avoid a high voltage shock from the many large capacitors attached to the board.
    • If necessary, remove the tape covering the inverter cable.
  39. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 39、 1の画像 1
    • Disconnect the inverter cable by pulling the connector away from its socket.
  40. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 40、 1の画像 1
    • If necessary, remove the tape covering the metal chassis where the AC-In cable resides.
    • This tape may be clear or black depending on your iMac unit.
  41. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 41、 2の画像 1 iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 41、 2の画像 2
    • Use a pair of tweezers to pull the AC-In cable out from underneath the chassis.
  42. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 42、 1の画像 1
    • Disconnect the AC-In cable by depressing the lock mechanism while pulling the connector away from its socket.
  43. iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 43、 2の画像 1 iMac Intel 20" EMC 2105 and 2118 Power Supply Replacement: 手順 43、 2の画像 2
    • Remove four T10 Torx screws securing the power supply to the rear case.
    • The fine-thread screw belongs in the lower right corner of the power supply. When reinstalling the power supply, install the fine-threaded screw first.
    • Lift the power supply out of the rear case, minding the AC-in cable that may get caught.
    • Do not touch the face of the power supply board to avoid electric shock.
終わりに
82 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Walter Galan
694,692 ポイント
1,203のガイドは作成済み
9 件のコメント
Excellent guide !
geonosysinfo - 返信
This guide was awesome. The iMac power supply replacement is a lot of work/steps but fixed an intermittent power supply problem for less than a $100 US dollars.
Pragmatic - 返信
43 Steps? Seriously?
Come on guys you can do it in 21.
http://ifixit-guide-pdfs.s3.amazonaws.co...
rfolsey - 返信
43 steps? Yikes!
Here is a much quicker way
rfolsey - 返信
Great guide! Powered down computer prior to vacation and came back to find it non-operative. This guide, about 90 minutes, and a $50 replacement power supply off of ebay and it is back up and running. This is a secondary computer we don't use much any more, but I hated to throw it out when it was still working for what we were using it for. Thanks so much!
gkar1013 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 66,806
