この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Remove the display to access most of your iMac's internals.
必要な工具と部品
Loosen the two Phillips screws securing the access door to your iMac.
Remove the access door.
Remove the following screws along the lower edge of your iMac:
Three 6 mm T8 Torx screws
One 8 mm T8 Torx screw (Right side of the RAM slot on 2105)
この手順で使用する道具:Plastic Cards$2.99
Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
If the bezel refuses to release, try lifting the lower edge of the front bezel slightly away from the rear case (detailed in the next few steps) and repeat the latch release process.
Lay your iMac stand-side down on a flat surface.
To lift the front bezel off the iMac, simultaneously:
Use your thumbs to press in the RAM arms and hold the iMac down.
Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
Pull the front bezel up with your index fingers.
Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
Remove the two 5 mm T6 Torx screws securing the display data cable connector to the logic board.
Pull the display data cable connector up off the logic board by its black pull tab.
19 の人々がこのガイドを完成させました。
