メインコンテンツにスキップ
この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
iMac Intel 17" Hard Drive Replacement
必要条件のみ
この修理ガイドは、他のガイドの前提条件として使用されます。それ自体は不完全で、単独で使用されることはありません。
必要な工具と部品
  1. iMac Intel 17" Hard Drive Replacement, Hard Drive: 手順 1、 1の画像 1
    • De-route the bundle of power supply cables from behind the hard drive bracket.
  2. iMac Intel 17" Hard Drive Replacement: 手順 2、 3の画像 1 iMac Intel 17" Hard Drive Replacement: 手順 2、 3の画像 2 iMac Intel 17" Hard Drive Replacement: 手順 2、 3の画像 3
    • A hard drive thermal sensor may be present on some models. If your logic board is missing the hard drive thermal sensor socket highlighted in red in the first picture, skip this step.
    • Pull the hard drive thermal sensor connector away from its socket on the logic board.
    • Pull this connector parallel to the face of the logic board toward the top edge of the iMac.
    • Use a spudger to pry the thermal sensor and adhesive off the hard drive and install it in the same location on the replacement drive.
  3. iMac Intel 17" Hard Drive Replacement: 手順 3、 1の画像 1
    • Press the hard drive bracket down to free it from the rear case, then rotate the top of the drive toward yourself.
    • Pressing the top of the hard drive bracket down to release it from the rear case requires a substantial amount of force, so we recommend laying your iMac stand-side down on a table to avoid knocking it over.
    • If you have trouble releasing the hard drive bracket, it can be removed from the hard drive, by removing the two T8 or T10 Torx screws securing the bracket to the drive.
  4. iMac Intel 17" Hard Drive Replacement: 手順 4、 2の画像 1 iMac Intel 17" Hard Drive Replacement: 手順 4、 2の画像 2
    • Lift the hard drive off its lower pins and pull it out of the rear case, minding the power supply cables that may get caught.
    • When reinstalling your hard drive, be careful not to push the two rubber grommets through their holes in the chassis. Retrieving them would require removing the logic board.
  5. iMac Intel 17" Hard Drive Replacement: 手順 5、 2の画像 1 iMac Intel 17" Hard Drive Replacement: 手順 5、 2の画像 2
    • Insert a spudger between the SATA connectors and twist it to separate the connector from the hard drive.
    • Disconnect both SATA connectors.
終わりに
作成者
7人の作成者と共同で作成されました。
Walter Galan
694,638 ポイント
1,203のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,155
