このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
Remove the three T8 Torx screws securing the front bezel to the rear case along the lower edge of the iMac.
この手順は未翻訳です。 翻訳を手伝う。
この手順で使用する道具:Plastic Cards$2.99-
Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
133 の人々がこのガイドを完成させました。
4 件のコメント
Awesome instructable!
Mike Kurtz - 返信
Used this same guide to replace the HDD on an A1207 iMac.
Almost identical except for the positioning of the display cable which is on the right hand side of the logic board.
Only problem was the four Torx screws holding in the display. They are so deeply recessed that I had to buy a set of Torx wrenches with long shafts as the Torx heads in the iFixit kit I have are too short.
Good guide.
