この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Upgrade your hard drive for more storage space.
必要な工具と部品
Orient the iMac face-side down on a table with the bottom edge facing yourself.
Remove the two Phillips screws securing the access door to the bottom grille of your iMac.
Remove the three T8 Torx screws securing the front bezel to the rear case along the lower edge of the iMac.
この手順で使用する道具:Plastic Cards$2.99
Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
Peel the lower EMI shield off the lower edge of the iMac and off the two vertical 4" sections on either side of the iMac.
Remove the two T6 Torx screws securing the display data cable connector to the logic board.
Disconnect the hard drive thermal sensor from the logic board by pulling its connector toward the top edge of your iMac.
Remove the two T8 Torx screws securing the hard drive bracket to the connector side of the hard drive.
Remove the hard drive bracket.
133 の人々がこのガイドを完成させました。
4 件のコメント
Awesome instructable!
Mike Kurtz - 返信
Used this same guide to replace the HDD on an A1207 iMac.
Almost identical except for the positioning of the display cable which is on the right hand side of the logic board.
Only problem was the four Torx screws holding in the display. They are so deeply recessed that I had to buy a set of Torx wrenches with long shafts as the Torx heads in the iFixit kit I have are too short.
Good guide.
