メインコンテンツにスキップ
iMac G5 20" Model A1145 CPU Fan Replacement
必要な工具と部品
  1. iMac G5 20" Model A1145 CPU Fan Replacement, Access Door: 手順 1、 1の画像 1
    • Orient the iMac face-side down on a table with the bottom edge facing yourself.
    • Remove the two Phillips screws securing the access door to the bottom grille of your iMac.
    • The screws are captive in the access door.
    • Before beginning the repair, unplug the computer and press and hold the power switch for 20-30 seconds, to discharge internal capacitors.
  2. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 2、 1の画像 1
    • Remove the access door.
  3. iMac G5 20" Model A1145 CPU Fan Replacement, Front Bezel: 手順 3、 1の画像 1
    • Remove the three T8 Torx screws securing the front bezel to the rear case along the lower edge of the iMac.
  4. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 4、 2の画像 1 iMac G5 20" Model A1145 CPU Fan Replacement: 手順 4、 2の画像 2
    • Turn the computer over.
    • Use your thumbs to press both RAM arms in past the front bezel for enough clearance to lift it off the rear case.
  5. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 5、 1の画像 1
    • While holding the RAM arms in with your thumbs, lift the lower edge of the front bezel enough to clear the rear case.
  6. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 6、 3の画像 1 iMac G5 20" Model A1145 CPU Fan Replacement: 手順 6、 3の画像 2 iMac G5 20" Model A1145 CPU Fan Replacement: 手順 6、 3の画像 3
    この手順で使用する道具:
    Plastic Cards
    $2.99
    購入する
    • Re-orient your iMac so it sits upright on the stand.
    • Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
    • Push the card toward the top of the iMac to release the front bezel latch.
    • Pull the front bezel away from the rear case.
    • Repeat this process for the other side of the front bezel.
    • It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches.
    • If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
    • Alternatively, you can use a strong magnet by holding it to the front top left/right corner of the display. You will hear a snapping sound when the hatch is released.
  7. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 7、 1の画像 1
    • Lay your iMac stand-side down on a table.
    • Lift the front bezel from its lower edge and rotate it away from the rest of your iMac, minding the RAM arms that may get caught.
    • Lay the front bezel above the rest of the iMac.
  8. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 8、 1の画像 1
    • If necessary, remove the piece of kapton tape wrapped around the microphone and camera connectors.
  9. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 9、 2の画像 1 iMac G5 20" Model A1145 CPU Fan Replacement: 手順 9、 2の画像 2
    • Disconnect both the camera and microphone cables.
  10. iMac G5 20" Model A1145 CPU Fan Replacement, Lower EMI Shield: 手順 10、 1の画像 1
    • Peel the lower EMI shield off the lower edge of the iMac and off the two vertical 4" sections on either side of the iMac.
    • It is not necessary to peel the lower EMI shield off the display.
  11. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 11、 1の画像 1
    • Tape the lower EMI shield up against the face of the display to keep it out of the way while you work.
  12. iMac G5 20" Model A1145 CPU Fan Replacement, Display: 手順 12、 1の画像 1
    • Remove the two T6 Torx screws securing the display data cable connector to the logic board.
  13. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 13、 1の画像 1
    • To disconnect the display data cable, grab its connector's black tab and pull it away from the face of the logic board.
  14. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 14、 1の画像 1
    • Peel back the two EMI tape strips from the left and right edges of the display.
    • During reassembly, it is helpful to use several small strips of tape to hold the EMI shielding along the left and right edges of the display footprint out of the way before lowering the display into the rear case of your iMac.
  15. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 15、 2の画像 1 iMac G5 20" Model A1145 CPU Fan Replacement: 手順 15、 2の画像 2
    • Remove the four recessed T10 Torx screws securing the display to the rear case.
    • Bit drivers tend to be too short to reach these screws. Be sure to have a magnetic thin-shafted T10 Torx screwdriver on hand.
  16. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 16、 1の画像 1
    • Lift the lower edge of the display slightly out of the rear case.
    • Disconnect both inverter cables (shown in red) by pulling their connectors toward the bottom edge of your iMac.
  17. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 17、 1の画像 1
    • Lift the display until it is nearly perpendicular to the rear case.
    • Disconnect the remaining two inverter cables (shown in red) by pulling their connectors toward the top edge of your iMac.
  18. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 18、 1の画像 1
    • While holding the display perpendicular to the rear case, pull it upward to peel off the EMI shield stuck to its upper edge.
  19. iMac G5 20" Model A1145 CPU Fan Replacement, Logic board: 手順 19、 1の画像 1
    • Disconnect the IR board cable by pulling its connector away from the socket on the IR board.
  20. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 20、 2の画像 1 iMac G5 20" Model A1145 CPU Fan Replacement: 手順 20、 2の画像 2
    • Remove the two T6 Torx screws securing the IR board bracket to the IR board.
  21. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 21、 1の画像 1
    • De-route the IR cable from under the aluminum heat sink and tuck it behind the optical drive to keep it out of the way.
  22. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 22、 2の画像 1 iMac G5 20" Model A1145 CPU Fan Replacement: 手順 22、 2の画像 2
    • Remove the single T10 Torx screw securing the left speaker to the rear case.
    • The screw for the left speaker has coarse threads.
    • Lift the left speaker out of the rear case and de-route its cable across the logic board.
  23. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 23、 2の画像 1 iMac G5 20" Model A1145 CPU Fan Replacement: 手順 23、 2の画像 2
    • Remove the single T10 Torx screw securing the right speaker to the rear case.
    • The right speaker screw has fine threads.
    • Lift the right speaker out of the rear case, minding the short cable between the speaker and its connector (located slightly above the right speaker).
  24. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 24、 1の画像 1
    • Disconnect the speakers from the logic board by pulling their connector toward the top edge of the iMac.
  25. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 25、 1の画像 1
    • Remove the two Phillips or two T6 Torx screws securing the AirPort/Bluetooth board to the logic board.
  26. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 26、 1の画像 1
    • Use your finger to lift the AirPort/Bluetooth board from its left edge, disconnecting it from the logic board.
    • Lift the board from its left edge only.
  27. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 27、 2の画像 1 iMac G5 20" Model A1145 CPU Fan Replacement: 手順 27、 2の画像 2
    • Use the flat end of a spudger to pry both antenna cable connectors up off the AirPort/Bluetooth board.
  28. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 28、 2の画像 1 iMac G5 20" Model A1145 CPU Fan Replacement: 手順 28、 2の画像 2
    • Disconnect the DC-in cable by simultaneously depressing both locking arms and pulling its connector away from the socket on the logic board toward the top of your iMac.
    • After both locking arms pass their retaining tabs, it is helpful to push the arms toward the top edge of your iMac while wiggling the connector.
  29. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 29、 1の画像 1
    • Disconnect the ambient light sensor by pulling its connector away from the face of the logic board.
  30. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 30、 2の画像 1 iMac G5 20" Model A1145 CPU Fan Replacement: 手順 30、 2の画像 2
    • Disconnect the optical drive fan from the logic board.
    • To aid in removal, it is helpful to use both of your thumbnails to push the ears on either side of the connector toward the top edge of the iMac.
  31. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 31、 2の画像 1 iMac G5 20" Model A1145 CPU Fan Replacement: 手順 31、 2の画像 2
    • Disconnect the IR/camera cable from the logic board.
    • This connector is especially wide and prone to breakage.
    • To aid in removal, it is helpful to use one hand to pinch the cables against a spudger and pull up toward the top edge of the iMac while pulling up gently on the cables with your other hand.
  32. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 32、 1の画像 1
    • Disconnect the optical drive thermal sensor cable from the logic board by pulling its connector toward the left edge of the iMac.
  33. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 33、 1の画像 1
    • Remove the two T6 Torx screws securing the optical drive connector to the logic board.
  34. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 34、 1の画像 1
    • Use the flat end of a spudger to pry the optical drive connector up off the logic board.
    • It is helpful to insert the spudger under the top or bottom edge of the connector and twist to separate the connector from the logic board.
  35. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 35、 1の画像 1
    • Disconnect the CPU fan from the logic board by pulling its connector toward the top edge of the iMac.
  36. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 36、 1の画像 1
    • Disconnect the hard drive thermal sensor from the logic board by pulling its connector toward the top edge of the iMac.
  37. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 37、 1の画像 1
    • Disconnect the hard drive fan by pulling its connector away from the face of the logic board.
  38. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 38、 1の画像 1
    • Disconnect the power button cable by pulling its connector away from the face of the logic board.
  39. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 39、 1の画像 1
    • Remove the two T6 Torx screws near the top of the heat sinks.
  40. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 40、 1の画像 1
    • Remove the following seven screws securing the logic board to the rear case:
    • Three coarse-thread T10 Torx.
    • Three fine-thread T10 Torx.
    • One long coarse-thread T10 Torx.
  41. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 41、 2の画像 1 iMac G5 20" Model A1145 CPU Fan Replacement: 手順 41、 2の画像 2
    • Tuck the RAM arms into the iMac so they rest on the perforated metal grille along its lower edge.
  42. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 42、 1の画像 1
    • Rotate the top of the logic board toward yourself slightly.
    • Pull the right edge of the logic board toward yourself slightly to free the I/O ports from the rear case, being careful not to bend the board.
    • Continue rotating the board toward yourself until you have enough room to reach the SATA connector, shown in the next step.
  43. iMac G5 20" Model A1145 CPU Fan Replacement: 手順 43、 2の画像 1 iMac G5 20" Model A1145 CPU Fan Replacement: 手順 43、 2の画像 2
    • Continue rotating the board toward yourself until you have enough room to reach the SATA connector (shown in red).
    • Insert the blunt end of a metal spudger between the SATA connector and its socket. Twist the shaft of the metal spudger to separate the connector from its socket.
    • Disconnect the SATA cable from the logic board.
    • Lift the logic board out of the rear case by its edges, minding any cables that may get caught.
  44. iMac G5 20" Model A1145 CPU Fan Replacement, CPU Fan: 手順 44、 1の画像 1
    • Lift the CPU fan off the plastic posts protruding from the rear case.
終わりに
4 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Walter Galan
694,561 ポイント
1,203のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 12,446
