はじめに
Use this guide to replace your CR2032 PRAM battery.
必要な工具と部品
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Lift the AirPort card slightly by its plastic tab and pull it straight away from its socket.
Remove the two 5.5 mm T6 Torx screws securing the AirPort bracket to the logic board.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
