はじめに
Regain Bluetooth functionality by replacing the Bluetooth board.
必要な工具と部品
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Remove the two 5.5 mm T6 Torx screws securing the Bluetooth board to the logic board.
Use a spudger to pry the Bluetooth antenna connector up off the Bluetooth board.
コメント 1 件
Greetings Walter Galan, I would like to know if I can install this iMac G5 20" Model A1076 Bluetooth board into my iMac 21 system, it say’s that no wireless is installed.
Please Advise!
Thank You In Advance & Have A Good One!!!.
R.Askew
Some models (with light sensor) have only the two outboard screws.
Robert Huber - 返信
