この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Is your iMac always mute? Replace your blown out speakers to keep your iMac singing like it should.
必要な工具と部品
この手順で使用する道具:Plastic Cards$2.99
Insert a plastic card up into the corner of the air vent slot at the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
Remove the single 5 mm T6 Torx screw securing the IR board bracket to the logic board.
Remove the IR cable finger and move the IR board, with cable still attached, out of the way.
2 の人々がこのガイドを完成させました。
