はじめに
Is your iMac dead to the world? A fried power supply could be the problem.
必要な工具と部品
Insert a plastic card up into the corner of the air vent slot at the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
Disconnect the hard drive thermal sensor by pulling the connector away from its socket parallel to the face of the hard drive.
Pull the power supply cable connector away from its socket to disconnect it from the DC to DC board.
16 の人々がこのガイドを完成させました。
