はじめに
The PRAM battery is located underneath the logic board.
ツール
パーツ
パーツは指定されていません。
Remove the single 5 mm T6 Torx screw securing the IR board bracket to the logic board.
Remove the IR cable finger and move the IR board, with cable still attached, out of the way.
Disconnect the CPU fan connector from the logic board by pulling it straight up from its socket.
Disconnect the hard drive data cable connector from the logic board by pulling it straight up from its socket.
Lift the edge of the PRAM battery slightly with your fingertip and use a spudger to slide the PRAM battery out from under its socket's metal clip.
3 の人々がこのガイドを完成させました。
