はじめに
Use this guide to replace your logic board.
ツール
パーツ
パーツは指定されていません。
Remove the single 5 mm T6 Torx screw securing the IR board bracket to the logic board.
Remove the IR cable finger and move the IR board, with cable still attached, out of the way.
Disconnect the CPU fan connector from the logic board by pulling it straight up from its socket.
Disconnect the hard drive data cable connector from the logic board by pulling it straight up from its socket.
18 の人々がこのガイドを完成させました。
