この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
An operational CPU fan is essential for keeping processor temperatures down.
必要な工具と部品
この手順で使用する道具:Plastic Cards$2.99
Insert a plastic card up into the corner of the air vent slot at the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
Remove the single T10 Torx screw securing the left speaker to the rear case.
Lift the left speaker out of the rear case and set it aside.
New line.
2 の人々がこのガイドを完成させました。
