はじめに
Trip over your power cord? Use this guide to replace your AC power inlet.
必要な工具と部品
この手順で使用する道具:Plastic Cards$2.99
Insert a plastic card up into the corner of the air vent slot at the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
Remove the single 5 mm T6 Torx screw securing the IR board bracket to the logic board.
Remove the IR cable finger and move the IR board, with cable still attached, out of the way.
Disconnect the CPU fan connector from the logic board by pulling it straight up from its socket.
Use a pair of tweezers to pull the AC-in cable out from underneath the chassis.
2 の人々がこのガイドを完成させました。
