はじめに
Keep processor temperatures down by replacing your broken fans.
必要な工具と部品
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Remove the two Phillips screws securing the fan cover to the midplane.
Lift the fan cover up off midplane.
Disconnect the hard drive data cable connector from the logic board by pulling its connector straight up.
ある他の人がこのガイドを完成しました。
