はじめに
Remove your rear panel to gain access to your iMac's internals.
パーツ
パーツは必要ありません。
  1. Lay the iMac display-side down on a flat surface.
    • Lay the iMac display-side down on a flat surface.
    • Loosen the three Phillips screws securing the rear panel to the iMac.
    • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
  2. Lift the rear panel slightly from the bottom edge of the iMac.
    • Lift the rear panel slightly from the bottom edge of the iMac.
    • Pull the rear panel toward yourself and remove it from the iMac.
まとめ
14 の人々がこのガイドを完成させました。
Walter Galan
576,305 ポイント
1,203のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 8
今までの合計 10,137
