Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
Lift the AirPort card slightly by its plastic tab and pull it straight away from its socket.
During reinstallation, insert the AirPort card such that the antenna side is nearest the center of the logic board.
Insert the flat end of a spudger between the body of the AirPort card and its antenna connector.
Push the spudger away from the AirPort card to disconnect the AirPort antenna.
When reassembling your iMac, be sure to insert the AirPort card the way it was before disassembly.
Slightly insert the tip of a spudger (or any other small wedge-shaped object) under the PRAM battery directly across from its retaining clip.
Do not bend the metal retaining clip up, as it is brittle and will break.
Use another spudger to slide the PRAM battery out from under its socket's retaining clip.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
1つの手順
全ガイド
小サイズ - 600px
中サイズ - 800px
大サイズ - 1200px
プレビュー
