はじめに
Remove your midplane assembly to gain access to your display and front bezel.
必要な工具と部品
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Remove the three 8 mm brass Phillips screws securing the optical drive to the midplane.
Slide the inverter-to-display cable connector from under the metal clip on the midplane.
Rotate the center Phillips screw on the bottom of the iMac clockwise until the rear panel clamp contacts the edge of the case.
Grab the power supply from each side and rotate its top edge toward yourself until it clears the logic board.
Lift the power supply out of the midplane.
Bend the case at the rear panel clamp enough to clear the panel clamp while lifting out the power supply using the two captive screws as handles.
Remove the two Phillips screws securing the fan cover to the midplane.
Lift the fan cover up off midplane.
6 の人々がこのガイドを完成させました。
My iMac has only ONE catch, the central one, so the two outer screws are not to be touched.
In fact, I tried so hard to unscrew them, with a good screwdriver, that my hand hurt. Knowing that some times captive things (like these screws or a faucet) can be already at the end of their travel and we only lock them further into that position, I tried both screwing and unscrewing to no avail.
paulfrancoeur - 返信
The two outer screws each drive a locking bar that engage tabs on the rear panel.
They definitely need to be unscrewed.
Dale Stanbrough -
That chick MJ is sexy!!!!!
djmadcracker - 返信
Looks like one of these screws is not like the others... a security Philips?! Never seen one of those before.
Terry Mullane - 返信
Please Note: If your iMac has an antenna for the airport extreme and not the bluetooth card. Don't buy the bluetooth get the airport extreme instead. Also, some newer devices may not work with these units.
James Janota - 返信
Just want to say thank you to ifixit! You guys are amazing and so helpful! This was so easy to do and I ordered the part I needed as well! We are up and running over here and my 7 year old son could not be any happier! Thank you!
mary nicolazzo - 返信
These are the easiest way to resolve the Wireless connectivity at my home. Thanks ifixit for sharing this.
Geek Squad - 返信
