はじめに
Regain Bluetooth functionality by replacing your Bluetooth board.
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Remove the two 5.5 mm T6 Torx screws securing the Bluetooth board to the logic board.
10 の人々がこのガイドを完成させました。
コメント1件
WARNING: The last iMac G5 17" ALS (no isight) to be made does NOT have a dedicated bluetooth board.
I followed this guide and ended up removing the fax/data modem which is above the bluetooth board in this guide.
The last iMac G5's (17" no isight) to be made have a Airport Extreme/Bluetooth combo board:
http://www.applemacparts.co.uk/store/pow...
This is located to the right of the battery.
