メインコンテンツにスキップ
iMac G5 17" Model A1058 Bluetooth Board Replacement
必要な工具と部品
  1. iMac G5 17" Model A1058 Bluetooth Board Replacement, Rear Panel: 手順 1、 1の画像 1
    • Lay the iMac display-side down on a flat surface.
    • Loosen the three Phillips screws securing the rear panel to the iMac.
    • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
  2. iMac G5 17" Model A1058 Bluetooth Board Replacement: 手順 2、 3の画像 1 iMac G5 17" Model A1058 Bluetooth Board Replacement: 手順 2、 3の画像 2 iMac G5 17" Model A1058 Bluetooth Board Replacement: 手順 2、 3の画像 3
    • Lift the rear panel slightly from the bottom edge of the iMac.
    • Pull the rear panel toward yourself and remove it from the iMac.
  3. iMac G5 17" Model A1058 Bluetooth Board Replacement, Bluetooth Board: 手順 3、 1の画像 1
    • Remove the two 5.5 mm T6 Torx screws securing the Bluetooth board to the logic board.
  4. iMac G5 17" Model A1058 Bluetooth Board Replacement: 手順 4、 2の画像 1 iMac G5 17" Model A1058 Bluetooth Board Replacement: 手順 4、 2の画像 2
    • Bend a paper clip into a hook and use it to pull the Bluetooth board up off its socket on the logic board.
    • You may use a spudger to remove the Bluetooth board, but be sure to only apply upward force as any sideways force may cause the connector to shear off the Bluetooth board.
  5. iMac G5 17" Model A1058 Bluetooth Board Replacement: 手順 5、 1の画像 1
    • Use a spudger to pry the Bluetooth antenna connector up off the Bluetooth board.
終わりに
10 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Walter Galan
693,915 ポイント
1,203のガイドは作成済み
コメント 1 件
WARNING: The last iMac G5 17" ALS (no isight) to be made does NOT have a dedicated bluetooth board.
I followed this guide and ended up removing the fax/data modem which is above the bluetooth board in this guide.
The last iMac G5's (17" no isight) to be made have a Airport Extreme/Bluetooth combo board:
http://www.applemacparts.co.uk/store/pow...
This is located to the right of the battery.
Ben Goodman - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 13
今までの合計 15,925
