メインコンテンツにスキップ
iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement
必要な工具と部品
  1. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement, Bottom Plate: 手順 1、 1の画像 1
    • Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
  2. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: 手順 2、 1の画像 1
    • Loosen the four Phillips #0 screws.
  3. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: 手順 3、 1の画像 1
    • Carefully remove the base access panel.
  4. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement, Bottom Plate Housing: 手順 4、 2の画像 1 iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement, Bottom Plate Housing: 手順 4、 2の画像 2
    • Remove the four 25mm T-15 screws.
  5. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: 手順 5、 2の画像 1 iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: 手順 5、 2の画像 2
    • Open the housing plate.
    • Be gentle with the wires still connected to the logic board so as not to ruin the cables.
    • A fixed plug connector between the logic board and upper unit will cause some resistance. Pull gently but firmly.
  6. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement, Logic Board Assembly: 手順 6、 1の画像 1
    • Gently remove the cables marked in red.
  7. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: 手順 7、 1の画像 1
    • Remove the three metal 10mm T-15 screws.
    • Remove the one nylon 10mm T-15 screw.
  8. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: 手順 8、 1の画像 1
    • Using thumbs and forefingers, firmly grasp the battery holder in one hand while grasping the metal bar in the other. Gently lift and pull the logic board to release it.
    i followed instructions and the logic board is stuck in there! can’t find any answers on the web either. any ideas?
    the biohazard - 返信
終わりに
9 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
Justin
メンバー登録日: 10/05/11
303 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 21-22, Maness Fall 2011 Cal Poly, Team 21-22, Maness Fall 2011人のメンバー
CPSU-MANESS-F11S21G22
4 メンバー
13のガイドは作成済み
コメント 1 件
We need to say what cables to remove in step 6 of Logic Board Assembly
Courtney - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 48
今までの合計 10,520
