はじめに
Upgrade your RAM DIMM Module for more memory.
必要な工具と部品
Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
Remove the RAM module from the iMac.
10 の人々がこのガイドを完成させました。
2 件のコメント
Please correct the title, this is a 144 pin SODIMM, it is not a DIMM
The 168 pin DIMM is used in the internal socket.
Thanks For catching this Typo! :-)
