Place the computer monitor face down on a safe, harmless surface.
Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
These tabs lock the module in place and releasing them will cause the module to "pop" up.
Remove the RAM module from the iMac.
Open the base by carefully pulling straight off, do not rotate the cover.
Open slowly to ensure that no cables are damaged or disconnected.
Squeeze the small black tab and wiggle gently to remove the colored power cable.
Do not pull directly on the colored wires.
Do not remove black grounding wire.
Using a Torx #9 screw driver, remove the two 8.77mm screws holding the drive's shield onto your iMac G4.
Remove the drive shield from your iMac.
Grasp the HD/Optical Drive bundle by the by the sides and gently wiggle it loose from the sides.
Ensure there are no wires passing over the top of the drive bundle when removing it, as it may unintentionally disconnect something.
Unplug the power source from the optical drive by pinching the plastic base of the connector and wiggling it gently.
Do not use excessive force, or pull on the wires directly, in order to unplug the connector from the drive.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
