この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This step will help you connect to wireless internet and get you back to surfing the internet faster than before. You can add a AirPort to your computer even if it did not originally come with one.
必要な工具と部品
Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
14 の人々がこのガイドを完成させました。
3 件のコメント
Make sure to insert the AirPort Card with the label facing down, away from you.
Does the antennae cable not plug into the card - Your illustration shows a large cable simply taped on top of the card and, as far as I can see, a smaller thinner cable that appears to be going to the card. I have the bigger cable in my iMac but it dues not appear to fit into the card - Do Inhave the wrong card or something?
The big cable plugs into the card. The little cable is a drawing on the iMac to show you how the cable should go. You are right, Step 3 does show the cable on top of the card, not plugged into it.
Dave -
