メインコンテンツにスキップ
iMac G4 15" 700 MHz EMC 1873 AirPort Card Replacement
必要な工具と部品
  1. iMac G4 15" 700 MHz EMC 1873 AirPort Card Replacement, Outer Base Plate: 手順 1、 2の画像 1 iMac G4 15" 700 MHz EMC 1873 AirPort Card Replacement, Outer Base Plate: 手順 1、 2の画像 2
    • Place the computer monitor face down on a safe, harmless surface.
    • Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
  2. iMac G4 15" 700 MHz EMC 1873 AirPort Card Replacement: 手順 2、 1の画像 1
    • Remove the metal plate from bottom of the iMac G4.
    • The four screws do not completely separate from the metal plate.
  3. iMac G4 15" 700 MHz EMC 1873 AirPort Card Replacement, AirPort Card: 手順 3、 1の画像 1
    • Use a spudger to lift and remove the AirPort's antenna connector.
    • This step is only applicable to iMacs that came with an AirPort card installed.
終わりに
14 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Lilly
メンバー登録日: 10/11/11
632 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 5-32, Amido Fall 2011 Cal Poly, Team 5-32, Amido Fall 2011人のメンバー
CPSU-AMIDO-F11S5G32
4 メンバー
8のガイドは作成済み
3 件のコメント
Make sure to insert the AirPort Card with the label facing down, away from you.
Nathan Larsen - 返信
Does the antennae cable not plug into the card - Your illustration shows a large cable simply taped on top of the card and, as far as I can see, a smaller thinner cable that appears to be going to the card. I have the bigger cable in my iMac but it dues not appear to fit into the card - Do Inhave the wrong card or something?
roger - 返信
The big cable plugs into the card. The little cable is a drawing on the iMac to show you how the cable should go. You are right, Step 3 does show the cable on top of the card, not plugged into it.
Dave -
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 26
今までの合計 8,495
