この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The iMac G3 uses a tray-loading optical drive. It uses a PATA optical drive. This guide will show you how to change your computer's optical drive.
必要な工具と部品
Remove the two phillips #00 screws.
Then remove the board. This will reveal that it is a standard PATA drive.
Congrats, the drive is free! You can use any PATA-tray loading drive in the iMac G3 which means you can install a CDRW to burn CDs in OS9 or X(if using OSX,install that DVD writer) but, of course only original drives will match the great look of the iMac).
14 の人々がこのガイドを完成させました。
