メインコンテンツにスキップ
この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
iMac G3 Model M4984 Logic Board Replacement
必要な工具と部品
  1. iMac G3 Model M4984 Logic Board Replacement, Logic Board: 手順 1、 1の画像 1
    • The iMac G3. This was a great computer for the time, and had plenty of features.
  2. iMac G3 Model M4984 Logic Board Replacement: 手順 2、 1の画像 1
    • Start by flipping the iMac upside-down. It may help to lay it on a towel, so you don't damage the screen, or scratch the face.
  3. iMac G3 Model M4984 Logic Board Replacement: 手順 3、 3の画像 1 iMac G3 Model M4984 Logic Board Replacement: 手順 3、 3の画像 2 iMac G3 Model M4984 Logic Board Replacement: 手順 3、 3の画像 3
    • Remove this Phillips screw.
    • Using a flathead screwdriver, work your way around the bottom cover, until it comes off.
    • Then, lift the bottom cover up and out, and set it aside.
  4. iMac G3 Model M4984 Logic Board Replacement: 手順 4、 3の画像 1 iMac G3 Model M4984 Logic Board Replacement: 手順 4、 3の画像 2 iMac G3 Model M4984 Logic Board Replacement: 手順 4、 3の画像 3
    • Now, remove the DB-15 Video connector from the logic board.
    • It may be helpful to use a Phillips screwdriver to remove the thumbscrews.
  5. iMac G3 Model M4984 Logic Board Replacement: 手順 5、 3の画像 1 iMac G3 Model M4984 Logic Board Replacement: 手順 5、 3の画像 2 iMac G3 Model M4984 Logic Board Replacement: 手順 5、 3の画像 3
    • Remove the power cable from the logic board assembly.
  6. iMac G3 Model M4984 Logic Board Replacement: 手順 6、 2の画像 1 iMac G3 Model M4984 Logic Board Replacement: 手順 6、 2の画像 2
    • Remove the front panel connector.
  7. iMac G3 Model M4984 Logic Board Replacement: 手順 7、 3の画像 1 iMac G3 Model M4984 Logic Board Replacement: 手順 7、 3の画像 2 iMac G3 Model M4984 Logic Board Replacement: 手順 7、 3の画像 3
    • Now, remove these Phillips screws.
    • Now, grab the logic board assembly by the piece of plastic, and lift it out.
  8. iMac G3 Model M4984 Logic Board Replacement: 手順 8、 1の画像 1
    • The logic board assembly. This is the heart of the computer, it contains the motherboard, CPU, RAM, V-RAM, PRAM battery, the hard drive, and the optical drive.
終わりに
11 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Chris Green
メンバー登録日: 10/11/09
37,014 ポイント
49のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
321 メンバー
1,466のガイドは作成済み
コメント 1 件
Just did this on my Grape 333 Mhz and on my Lime 333 Mhz which come from from the same place. Actually, I'm surprised that the Grape's logic board has a white IrDA connector which its twin doesn't have...
Nicolas Zbinden - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 76
今までの合計 18,575
