メインコンテンツにスキップ
iMac G3 Model M4984 Logic Board Replacement
必要な工具と部品
  1. iMac G3 Model M4984 Logic Board Replacement, Logic Board: 手順 1、 1の画像 1
    • The iMac G3. This was a great computer for the time, and had plenty of features.
  2. iMac G3 Model M4984 Logic Board Replacement: 手順 2、 1の画像 1
    • Start by flipping the iMac upside-down. It may help to lay it on a towel, so you don't damage the screen, or scratch the face.
  3. iMac G3 Model M4984 Logic Board Replacement: 手順 3、 3の画像 1 iMac G3 Model M4984 Logic Board Replacement: 手順 3、 3の画像 2 iMac G3 Model M4984 Logic Board Replacement: 手順 3、 3の画像 3
    • Remove this Phillips screw.
    • Using a flathead screwdriver, work your way around the bottom cover, until it comes off.
    • Then, lift the bottom cover up and out, and set it aside.
  4. iMac G3 Model M4984 Logic Board Replacement: 手順 4、 3の画像 1 iMac G3 Model M4984 Logic Board Replacement: 手順 4、 3の画像 2 iMac G3 Model M4984 Logic Board Replacement: 手順 4、 3の画像 3
    • Now, remove the DB-15 Video connector from the logic board.
    • It may be helpful to use a Phillips screwdriver to remove the thumbscrews.
  5. iMac G3 Model M4984 Logic Board Replacement: 手順 5、 3の画像 1 iMac G3 Model M4984 Logic Board Replacement: 手順 5、 3の画像 2 iMac G3 Model M4984 Logic Board Replacement: 手順 5、 3の画像 3
    • Remove the power cable from the logic board assembly.
  6. iMac G3 Model M4984 Logic Board Replacement: 手順 6、 2の画像 1 iMac G3 Model M4984 Logic Board Replacement: 手順 6、 2の画像 2
    • Remove the front panel connector. (You may also need to remove an additional screw that connects the front panel connector to the logic board assembly).
  7. iMac G3 Model M4984 Logic Board Replacement: 手順 7、 3の画像 1 iMac G3 Model M4984 Logic Board Replacement: 手順 7、 3の画像 2 iMac G3 Model M4984 Logic Board Replacement: 手順 7、 3の画像 3
    • Now, remove these Phillips screws.
    • Now, grab the logic board assembly by the piece of plastic, and lift it out.
  8. iMac G3 Model M4984 Logic Board Replacement: 手順 8、 1の画像 1
    • The logic board assembly. This is the heart of the computer, it contains the motherboard, CPU, RAM, V-RAM, PRAM battery, the hard drive, and the optical drive.
終わりに
11 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Chris Green
メンバー登録日: 10/11/09
36,978 ポイント
49のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,521のガイドは作成済み
コメント 1 件
Just did this on my Grape 333 Mhz and on my Lime 333 Mhz which come from from the same place. Actually, I'm surprised that the Grape's logic board has a white IrDA connector which its twin doesn't have...
Nicolas Zbinden - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 17
過去 30 日: 67
今までの合計 18,526
