はじめに
Prerequisite-only guide to replace the logic board assembly in an iMac 27" 2017.
必要な工具と部品
Use a T5 Torx screwdriver to remove the two 4 mm screws securing the AirPort/Bluetooth antenna cables.
Use the tip of a spudger to flip open the retaining flap on the microphone ribbon cable ZIF socket.
Use tweezers to gently pull the microphone ribbon cable straight out of its socket.
もう少しです!
終わりに
