メインコンテンツにスキップ
iLive IKBC384S FM/AM Antenna Replacement
必要な工具と部品
  1. iLive IKBC384S  FM/AM Antenna Replacement, Top Cover: 手順 1、 2の画像 1 iLive IKBC384S  FM/AM Antenna Replacement, Top Cover: 手順 1、 2の画像 2
    • Make sure you remove all seven 3 mm screws before proceeding to the next step.
  2. iLive IKBC384S  FM/AM Antenna Replacement: 手順 2、 2の画像 1 iLive IKBC384S  FM/AM Antenna Replacement: 手順 2、 2の画像 2
    • Use iOpener or heat gun on all sides except the front.
  3. iLive IKBC384S  FM/AM Antenna Replacement: 手順 3、 2の画像 1 iLive IKBC384S  FM/AM Antenna Replacement: 手順 3、 2の画像 2
    • Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
    • The top of the device will be very difficult to remove because of the adhesive holding it together.
  4. iLive IKBC384S  FM/AM Antenna Replacement, FM/AM Antenna: 手順 4、 2の画像 1 iLive IKBC384S  FM/AM Antenna Replacement, FM/AM Antenna: 手順 4、 2の画像 2
    • Remove all four screws(13.5 mm in length) that are securing the disk drive.
  5. iLive IKBC384S  FM/AM Antenna Replacement: 手順 5、 2の画像 1 iLive IKBC384S  FM/AM Antenna Replacement: 手順 5、 2の画像 2
    • Unplug the ribbon cable connected to the motherboard that stems from the disc drive.
    • Also, disconnect the two power connectors from the motherboard.
    • Once you have removed the ribbon cables and two connectors on the motherboard the disk drive can be removed.
  6. iLive IKBC384S  FM/AM Antenna Replacement: 手順 6、 1の画像 1
    • After removing the top of the device, locate the screws on the motherboard. Gently unscrew all four of the 3.5mm screws on the motherboard.
  7. iLive IKBC384S  FM/AM Antenna Replacement: 手順 7、 2の画像 1 iLive IKBC384S  FM/AM Antenna Replacement: 手順 7、 2の画像 2
    • Desolder the antenna at the contact point.
    • Check out this awesome guide for soldering and desoldering tips.
  8. iLive IKBC384S  FM/AM Antenna Replacement: 手順 8、 2の画像 1 iLive IKBC384S  FM/AM Antenna Replacement: 手順 8、 2の画像 2
    • Place iOpener on antenna for approximately 5 minutes
  9. iLive IKBC384S  FM/AM Antenna Replacement: 手順 9、 1の画像 1
    • Lift up and remove all of the antenna.
    • The antenna will be glued down all the way around the radio
終わりに
作成者
2人の作成者と共同で作成されました。
Tracy Walts
メンバー登録日: 03/21/17
201 ポイント
2のガイドは作成済み
チーム
Texas Tech, Team S46-G6, Bennett Spring 2017 Texas Tech, Team S46-G6, Bennett Spring 2017人のメンバー
TTU-BENNETT-S17S46G6
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 677
