はじめに
After replacing the battery and charging problems still persist, use this guide to replace the charging node.
必要な工具と部品
Remove the rubber from the bottom of the speaker, use a medium blue plastic spudger to gently work its way under the rubber and slowly peel off for each of the three feet. The order does not matter.
Unscrew the two 11 mm Philips #1 screws on the charging nodes.
Remove the charging node from the speaker and set aside.
もう少しです!
終わりに
