メインコンテンツにスキップ
iHome iW1 Speaker Charging Nodes Replacement
必要な工具と部品
  1. iHome iW1 Speaker Charging Nodes Replacement, Battery: 手順 1、 3の画像 1 iHome iW1 Speaker Charging Nodes Replacement, Battery: 手順 1、 3の画像 2 iHome iW1 Speaker Charging Nodes Replacement, Battery: 手順 1、 3の画像 3
    • Remove the rubber from the bottom of the speaker, use a medium blue plastic spudger to gently work its way under the rubber and slowly peel off for each of the three feet. The order does not matter.
  2. iHome iW1 Speaker Charging Nodes Replacement: 手順 2、 2の画像 1 iHome iW1 Speaker Charging Nodes Replacement: 手順 2、 2の画像 2
    • Remove the six 11 mm Philips #1 screws found underneath the foam to remove the steel outer metal frame.
    • Once the screws come off, keep them safely off to the side.
  3. iHome iW1 Speaker Charging Nodes Replacement: 手順 3、 2の画像 1 iHome iW1 Speaker Charging Nodes Replacement: 手順 3、 2の画像 2
    • Remove the metal frame gently and set aside.
  4. iHome iW1 Speaker Charging Nodes Replacement: 手順 4、 2の画像 1 iHome iW1 Speaker Charging Nodes Replacement: 手順 4、 2の画像 2
    • Remove the two remaining 11 mm Philips #1 screws holding the base and set them aside.
  5. iHome iW1 Speaker Charging Nodes Replacement: 手順 5、 3の画像 1 iHome iW1 Speaker Charging Nodes Replacement: 手順 5、 3の画像 2 iHome iW1 Speaker Charging Nodes Replacement: 手順 5、 3の画像 3
    • Lift the base up gently keeping in mind that the base is connected with wires to internal parts of the speaker.
    • Disconnect the white bundled cable connector attached to the charging node using a spudger. The base of the speaker is now free to be removed.
  6. iHome iW1 Speaker Charging Nodes Replacement: 手順 6、 3の画像 1 iHome iW1 Speaker Charging Nodes Replacement: 手順 6、 3の画像 2 iHome iW1 Speaker Charging Nodes Replacement: 手順 6、 3の画像 3
    • Remove the white power cable connector that connects the charging node to the battery, using the plastic spudger.
    • Pry the battery off using the plastic spudger.
  7. iHome iW1 Speaker Charging Nodes Replacement, Charging Nodes: 手順 7、 3の画像 1 iHome iW1 Speaker Charging Nodes Replacement, Charging Nodes: 手順 7、 3の画像 2 iHome iW1 Speaker Charging Nodes Replacement, Charging Nodes: 手順 7、 3の画像 3
    • Unscrew the two 11 mm Philips #1 screws on the charging nodes.
    • Remove the charging node from the speaker and set aside.
終わりに
作成者
3人の作成者と共同で作成されました。
Victor Germino
メンバー登録日: 02/14/17
828 ポイント
8のガイドは作成済み
チーム
USF Tampa, Team 20-6, Remmell Spring 2017 USF Tampa, Team 20-6, Remmell Spring 2017人のメンバー
USFT-REMMELL-S17S20G6
4 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 856
