メインコンテンツにスキップ
iHome iPL8 Screen Replacement
必要な工具と部品
  1. iHome iPL8 Screen Replacement, Battery: 手順 1、 1の画像 1
    • Turn the device over to access the bottom panel.
    • Locate the 6mm Phillips #2 screw under the label "unscrew to open door."
  2. iHome iPL8 Screen Replacement: 手順 2、 1の画像 1
    • Using a Phillips #2 screwdriver, unscrew the captive screw.
    • Keep turning until the screw and the door are loose.
  3. iHome iPL8 Screen Replacement: 手順 3、 1の画像 1
    • Lift and remove the battery access panel.
    • The captive screw will remain attached to the panel.
  4. iHome iPL8 Screen Replacement: 手順 4、 2の画像 1 iHome iPL8 Screen Replacement: 手順 4、 2の画像 2
    • Gently press on the rim of the 3V battery.
    • Remove the 3V battery.
  5. iHome iPL8 Screen Replacement, Lightning Connector: 手順 5、 1の画像 1
    • Keeping your device upside-down, locate the four 6mm Phillips #2 screws near each corner.
    • Remove the four 6mm Phillips #2 screws.
  6. iHome iPL8 Screen Replacement: 手順 6、 1の画像 1
    • Remove the four round pads from the bottom of the device.
    • There are two additional 6mm Phillips #2 screws under the pads.
    • Using a Phillips #2 screwdriver, remove the two remaining screws.
    • Put your hand on the silver bottom case and gently pull it outward.
  7. iHome iPL8 Screen Replacement: 手順 7、 2の画像 1 iHome iPL8 Screen Replacement: 手順 7、 2の画像 2
    • Locate the green circuit board. This panel is clipped onto two black, circular-shaped columns at two corners.
    • Pull out the green circuit board on the two corners.
    • The green circuit board is attached to a black box at the bottom. Flip the panel and the black box together to open the device.
  8. iHome iPL8 Screen Replacement: 手順 8、 2の画像 1 iHome iPL8 Screen Replacement: 手順 8、 2の画像 2
    • Remove the two 2.5 mm Phillips #1 screws securing the lightning dock assembly to the device.
    • Remove the two screws and the black cover.
    • Gently remove the lightning dock assembly.
    • The lightning dock assembly is connected to wires.
  9. iHome iPL8 Screen Replacement: 手順 9、 3の画像 1 iHome iPL8 Screen Replacement: 手順 9、 3の画像 2 iHome iPL8 Screen Replacement: 手順 9、 3の画像 3
    • Remove the two 2.5mm screws using a Phillips #1 screwdriver.
    • Remove the back cover.
    • Use your fingers to reposition the lightning connector.
    • Make sure ALL of the lightning connector is exposed.
  10. iHome iPL8 Screen Replacement, Screen: 手順 10、 1の画像 1
    • Look at the side of the device. You will see a green panel connecting to the black box by a white stripe.
    • Remove the four 2.5 mm Phillips #1 screws on the green panel.
    • Flip the green panel to reveal the front of the screen.
  11. iHome iPL8 Screen Replacement: 手順 11、 2の画像 1 iHome iPL8 Screen Replacement: 手順 11、 2の画像 2
    • Locate the transparent, rectangular plastic screen cover.
    • Gently lift the cover off.
    • The screen is now revealed. Replace the screen with a functioning one.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Chen Zhong
メンバー登録日: 02/05/19
569 ポイント
4のガイドは作成済み
チーム
UC Davis, Team S18-G5, Lore Winter 2019 UC Davis, Team S18-G5, Lore Winter 2019人のメンバー
UCD-LORE-W19S18G5
3 メンバー
4のガイドは作成済み
1件のガイドコメント
Hi, I have one iHome iBN20 that needs to replace the screen too.
Please guide me to open up the casing.
Thank you.
Chan - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 285
